pin description innovate LM-2 analog I/O cable - P/N: 3811
hello,
does anyone can help me concerning the pins of the analog cable #3811. I should know the pin of the white/black and the blue wire (rpm wires) Thanks for help. fux
This should be it.
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
Thanks for quick reply.
The user manual with this scheme was delivered with the innovate LM-2. But I do not know which pin of the 14 pin connector/plug are connected with the black/white and the blue rpm-wires. I do not have the analog cable and so it is not possible to test it... |
I'll find my cable and check for you
... this would be great - thanks a lot! ...
Couldn't find my analog cable but I'll look again this afternoon.
I have numbered the pins based on the 1 and 14 molded into the side of the plug. the coresponding colors are as follows:
thank you very much for your efforts.
your answer will help me a lot! I am very happy :-) have a nice day ... |
