Solution for pressuring piston from caliper
When pistons are tight and partially frozen in calipers, it’s always been an issue for me to supply enough pressure to move them. Hose connections always leaked too much. I finally found a fitting that screws directly into the caliper’s brake line inlet. The good news is the pressure side has the same connection as a tire stem so it’s easy and leak free to apply pressure. I’ve posted a photo wi manufacturer’s information.
1979 Porsche 911SC Targa 1996 Porsche 993 C4S 2005 Porsche 996 Turbo S 2020 BMW X3M Competition 2003 BMW M5 Last edited by autobonrun; 04-06-2021 at 05:17 PM.. Reason: Spelling |
UMM, if you are trying to use a 1/8" NPT thread in place of the correct 10mm 1.0 pitch, then you are asking for problems. For thirty years of rebuilding calipers I have used a pedal cluster with master cylinder and brake lines to pop the pistons hydraulically. So you don't really need to remove from the car.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 Last edited by djpateman; 04-06-2021 at 05:26 PM.. |
I need a solution on my frozen cylinders too.. I like the pedal approach but I'm rebuilding
All my brake system. How about adapter to the 1/8 npt like this one. https://www.speedwaymotors.com/Earls-02112ERL-Hardline-Adapter-1-8-Inch-NPT-10mm-x-1-0-Concave,390758.html Oops.. I guess that's backwards.. I'm sure there's a 10 mm male to 1/8 female somewhere. |
RETIRED
Zirc fitting and a grease gun.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
1979 Porsche 911SC Targa 1996 Porsche 993 C4S 2005 Porsche 996 Turbo S 2020 BMW X3M Competition 2003 BMW M5 |
I’ll look into this setup. I know a tool store that probably has it. I’m not familiar with a Zirc fitting. I’ll need to research it. Do you just use regular brake fluid in the grease gun? I assume you don’t want to get grease in the caliper.
Easy to fab up something like this.
Wow. That’s a nice setup.
RETIRED
A zirc fitting is a grease fitting, use a grease gun with grease in it.
Old Indian trick as my Dadz would say.
Thanks.
RETIRED
Put a block of wood between the pistons and pump SLOWLY.....sometimes it can be quite explosive and you don't want them whacking themselves together.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 04-06-2021 at 06:48 PM.. |
Joe Bob is Correct. Just used it last week on 3 motorcycle calipers that had been sitting since 1992. Slick trick.
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
RETIRED
John Walker/Rube Goldberg
I used a diesel injector pump from Ebay adapted to the brake lines. Mine were frozen Solid!!! pumped them full of water to free them up. I used a rubber stopper to plug up the loose one and freed the other.
Slick!!!!! Platted and rebuilt them myself and turned out Sweet. |
I can’t imagine trying to rebuild a four or six piston caliper. Holding one in place made my day.
1979 Porsche 911SC Targa 1996 Porsche 993 C4S 2005 Porsche 996 Turbo S 2020 BMW X3M Competition 2003 BMW M5 Last edited by autobonrun; 04-06-2021 at 08:13 PM.. |
Use the grease gun. It's messy but a whole lot safer than using compressed air. I just removed some pistons from aluminium S calipers this way, works very well
just use the car. Pull the caliper off the disk and step on the break. One side will pop out. Gently use the the piston to clog the hole and step on the break again and the other piston will com out. no need to overcomplicate
You can’t pull the caliper off the disk with the close coupled hard metal brake line still attached. It’s an exact fit and there is zero give in the line. Otherwise good solution.
Did it a week ago. No issue at all.
Chris |
