Solution for pressuring piston from caliper
When pistons are tight and partially frozen in calipers, it’s always been an issue for me to supply enough pressure to move them. Hose connections always leaked too much. I finally found a fitting that screws directly into the caliper’s brake line inlet. The good news is the pressure side has the same connection as a tire stem so it’s easy and leak free to apply pressure. I’ve posted a photo wi manufacturer’s information.
http://forums.pelicanparts.com/uploa...1617754572.jpg http://forums.pelicanparts.com/uploa...1617754607.jpg |
UMM, if you are trying to use a 1/8" NPT thread in place of the correct 10mm 1.0 pitch, then you are asking for problems. For thirty years of rebuilding calipers I have used a pedal cluster with master cylinder and brake lines to pop the pistons hydraulically. So you don't really need to remove from the car.
I need a solution on my frozen cylinders too.. I like the pedal approach but I'm rebuilding
All my brake system. How about adapter to the 1/8 npt like this one. https://www.speedwaymotors.com/Earls-02112ERL-Hardline-Adapter-1-8-Inch-NPT-10mm-x-1-0-Concave,390758.html Oops.. I guess that's backwards.. I'm sure there's a 10 mm male to 1/8 female somewhere. |
Zirc fitting and a grease gun.
Easy to fab up something like this.
http://forums.pelicanparts.com/uploa...1617758528.JPG http://forums.pelicanparts.com/uploa...1617758528.JPG |
A zirc fitting is a grease fitting, use a grease gun with grease in it.
Old Indian trick as my Dadz would say. |
Put a block of wood between the pistons and pump SLOWLY.....sometimes it can be quite explosive and you don't want them whacking themselves together.
Thanks! |
John Walker/Rube Goldberg:D
I used a diesel injector pump from Ebay adapted to the brake lines. Mine were frozen Solid!!! pumped them full of water to free them up. I used a rubber stopper to plug up the loose one and freed the other.
Slick!!!!! Platted and rebuilt them myself and turned out Sweet. |
I can’t imagine trying to rebuild a four or six piston caliper. Holding one in place made my day. |
Use the grease gun. It's messy but a whole lot safer than using compressed air. I just removed some pistons from aluminium S calipers this way, works very well
just use the car. Pull the caliper off the disk and step on the break. One side will pop out. Gently use the the piston to clog the hole and step on the break again and the other piston will com out. no need to overcomplicate
Did it a week ago. No issue at all.
Chris |
| All times are GMT -8. The time now is 11:22 AM. |
