I used a rubber stopper drilled out in the center to plug the missing cylinder. This allowed me to plug the missing cylinder and have the other stuck piston pop out.
I adapted a diesel injector tester pump to a caliper brake line. Pumped them full of water to remove the pistons. I Originally used brake fluid but it made a huge mess. Dang, Water does not compress, Super clean and easy. I think I used a 1.5" rubber stopper. Worked awesome. |
| All times are GMT -8. The time now is 12:30 PM. |
