autobonrun's Avatar
Solution for pressuring piston from caliper
When pistons are tight and partially frozen in calipers, it’s always been an issue for me to supply enough pressure to move them. Hose connections always leaked too much. I finally found a fitting that screws directly into the caliper’s brake line inlet. The good news is the pressure side has the same connection as a tire stem so it’s easy and leak free to apply pressure. I’ve posted a photo wi manufacturer’s information.
1979 Porsche 911SC Targa
1996 Porsche 993 C4S
2005 Porsche 996 Turbo S
2020 BMW X3M Competition
2003 BMW M5
Old 04-06-2021, 05:17 PM
djpateman's Avatar
UMM, if you are trying to use a 1/8" NPT thread in place of the correct 10mm 1.0 pitch, then you are asking for problems. For thirty years of rebuilding calipers I have used a pedal cluster with master cylinder and brake lines to pop the pistons hydraulically. So you don't really need to remove from the car.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 04-06-2021, 05:24 PM
I need a solution on my frozen cylinders too.. I like the pedal approach but I'm rebuilding
All my brake system. How about adapter to the 1/8 npt like this one.
https://www.speedwaymotors.com/Earls-02112ERL-Hardline-Adapter-1-8-Inch-NPT-10mm-x-1-0-Concave,390758.html
Oops.. I guess that's backwards..
I'm sure there's a 10 mm male to 1/8 female somewhere.
Old 04-06-2021, 06:01 PM
RETIRED
Joe Bob's Avatar
Zirc fitting and a grease gun.
2012 ML350 3.0 Turbo Diesel
Old 04-06-2021, 06:12 PM
autobonrun's Avatar
I don’t think I’m a good enough mechanic to replace those o-rings in the calipers with the calipers still on the car. Doing it on the bench was challenge enough. Like you I was also concerned about the thread pitch difference, so I only threaded in until I met resistance. That was enough to be air tight without causing any damage to the thread. I like the idea of a grease gun. A non compressible liquid is always the preferred method to move a piston.
2003 BMW M5
Old 04-06-2021, 06:22 PM
autobonrun's Avatar
I’ll look into this setup. I know a tool store that probably has it. I’m not familiar with a Zirc fitting. I’ll need to research it. Do you just use regular brake fluid in the grease gun? I assume you don’t want to get grease in the caliper.
2003 BMW M5
Old 04-06-2021, 06:26 PM
Easy to fab up something like this.
206 637 4071
Old 04-06-2021, 06:27 PM
autobonrun's Avatar
Wow. That’s a nice setup.
2003 BMW M5
Old 04-06-2021, 06:28 PM
RETIRED
Joe Bob's Avatar
A zirc fitting is a grease fitting, use a grease gun with grease in it.
Old Indian trick as my Dadz would say.
Old 04-06-2021, 06:32 PM
autobonrun's Avatar
Thanks.
2003 BMW M5
Old 04-06-2021, 06:37 PM
RETIRED
Joe Bob's Avatar
Put a block of wood between the pistons and pump SLOWLY.....sometimes it can be quite explosive and you don't want them whacking themselves together.
Old 04-06-2021, 06:40 PM
LakeCleElum's Avatar
Joe Bob is Correct. Just used it last week on 3 motorcycle calipers that had been sitting since 1992. Slick trick.
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 04-06-2021, 06:46 PM
Excellent!! I might copy this one.
Thanks!
Old 04-06-2021, 07:17 PM
RETIRED
Joe Bob's Avatar
John Walker/Rube Goldberg
Old 04-06-2021, 07:20 PM
I used a diesel injector pump from Ebay adapted to the brake lines. Mine were frozen Solid!!! pumped them full of water to free them up. I used a rubber stopper to plug up the loose one and freed the other.
Slick!!!!!
Platted and rebuilt them myself and turned out Sweet.
Old 04-06-2021, 07:39 PM
autobonrun's Avatar
Slick!!!!!
I used the piston that popped out as my stopper by pressing it in slightly then held it in that position using a c-clamp while I applied pressure to the caliper. Both my rear calipers had a frozen piston. The fronts came out easily.
I can’t imagine trying to rebuild a four or six piston caliper. Holding one in place made my day.
2003 BMW M5
Old 04-06-2021, 08:10 PM
Arlo911's Avatar
Use the grease gun. It's messy but a whole lot safer than using compressed air. I just removed some pistons from aluminium S calipers this way, works very well
Old 04-07-2021, 12:33 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
just use the car. Pull the caliper off the disk and step on the break. One side will pop out. Gently use the the piston to clog the hole and step on the break again and the other piston will com out. no need to overcomplicate
Old 04-07-2021, 11:20 AM
autobonrun's Avatar
You can’t pull the caliper off the disk with the close coupled hard metal brake line still attached. It’s an exact fit and there is zero give in the line. Otherwise good solution.
2003 BMW M5
Old 04-07-2021, 01:31 PM
cmcfaul's Avatar
Did it a week ago. No issue at all.
Chris
Old 04-07-2021, 03:15 PM
