Verify "Matching Numbers" without COA?
I'm on a quest to verify that the engine and trans numbers on my 1987 Coupe prove that they are original to the car.
I have no reason to believe otherwise (they are "H" numbers indicating the year 1987) and the engine type is correct for the car as well. USA, Catalyst equipped. Older cars (like my 1978 SC) have a spot in the warranty book for such a thing but the later book doesn't. Although the option code sticker is there, it doesn't list the motor or trans numbers. I am preparing to sell the car and would like to be able to claim "matching numbers" with some certainty. With Porsche no longer supplying COA's how is this information obtained? I don't have a relationship with a dealer (nearest one is 500 miles away) so that's out. Thanks and all the best, Jon |
Not sure he can pull data on an 87 but have tried asking Dave Pateman?
Jon, do you have the sticker on the hood? Engine and tranny codes listed there right above the paint code.http://forums.pelicanparts.com/uploa...1618321678.jpg
I sure wish I'd gotten a COA when I had the chance. It's starting to look convenient and cheap! |
I just looked at the docs from my last car that had that sticker and those are only the engine type numbers, not the serial numbers (sample size one of one)
According to (stolen from another thread): http://forums.pelicanparts.com/uploa...1618323797.jpg |
Jon, yes now I see your dilemma, you have the correct engine/tranny type and serial numbers that should be in your car but can't tell to a certainty if they are the originals. I just assumed on mine. 930/21 is the right engine type and 64F-----is the right serial # range. Same with the tranny.
Well, I'm afraid I was wasting everyone's time. A quick email to the (somewhat) local dealer and I was all set! Information was very limited, but included exactly what I needed.
Thanks everyone! http://forums.pelicanparts.com/uploa...1618411069.jpg |
COA Accuracy
COAs are not always accurate. I have a 1966 912 Karmann coupe. Chassis and engine numbers match, but the transmission does not. TheCOA gives the transmission number as 228018-902/1, but on the transmission the serial number is stamped as 228013-902/1, and it is clear that the 3 is actually a partial strike of an 8 number die, with little to no pressure applied to the left side of the die.
I have a good history on this car, going back to when it was delivered to its original buyer in Germany, and I have a copy of th Kardex from the factory as well as the COA. The odds of the transmission being replaced at any time by a transmission numbered only 5 numbers earlier in sequence is phenomenally small so I don't obsess over the difference Today these numbers are machine applied, which should eliminate the possibility of error, but in the early days of six-digit VIN numbers these cars were built by small teams of workers using largely hand tools. Note: I had this transmission rebuilt four years ago with new bearings, synchros and the other usual stuff in a transmission rebuild. Cost $4,500 — about $150 less than the entire car cost in 1966! Jerry |
Woohoo, this worked for me. Thanks for the tip.
I emailed a parts manager at my local Porsche dealership and got the screenshot. There are several in my area so I chose the one that is the "Porsche Classic Specialist". I asked nicely and also showed a picture of the first page of my service book where the initial dealership did not fill out the space for the engine number on my '82 Targa. |
Pfft... I tried with my local Porsche dealer and they told me to call Porsche of North America...
In the Motor Vehicle Theft Law Act of 1984 beginning Sept. 1, 1986 cars were marked with theft identification tags with the VIN number. The engine and transmission were marked as well as other locations. TSB 8601 - Motor Vehicle Theft Law Act of 1984 lists all of the locations.
My 87 Carrera still has the tags but the engine and transmission labels are difficult to read. |
I wonder if there's anything in the law that requires the manufacturer to provide engine and trans numbers referenced to VIN? |
I reached out to my local Porsche dealer today and this is what they sent me. Just info on engine and gearbox type but no serial numbers. Are dealerships able to get the serial numbers?
http://forums.pelicanparts.com/uploa...1664985448.jpg |
I got a build sheet for my 85 Carrera from vinanalytics.com. Engine an trans serial numbers matched the car. Pretty much everything else matched the window sticker, and the sticker in the warranty book.
The only error was their interpretation of the two character interior code (VA is dark blue full leather, and they said VA was something else). The individual codes for the seats, etc. we all correct though. Price was very reasonable, $12 or so a couple of years ago. It is not a COA, no signature or fancy paper. But it does document the engine/trans numbers. —Dave Sent from my iPhone using Tapatalk |
1 Attachment(s)
| All times are GMT -8. The time now is 07:02 AM. |
