ancient novice
Possibly raw gas in exhaust but how to know
1981 911SC after engine partial rebuild, engine starts easily and runs well but looks like thin smoke from exhaust and gets thicker as it runs, but smells strongly of raw gas. The mechanic who did the work has retired and not available. No other local service available. As engine is running smoothly, where could raw gas be coming from ? Any advice would be greatly appreciated.
Old 04-17-2021, 07:51 AM
Hi peetie,
You may have two separate problems. The thicker smoke could be oil burning off of the heat exchangers depending on how many miles since rebuild.
For the gas smell, I would first stick my finger in the exhaust pipe and see if I could smell raw gas on my finger. If not I would try to find a leak by tracingthe fuel lines. A good steam clean top to bottom is also a good idea to help search for leaks.
Best of luck,
Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her!
Old 04-17-2021, 07:58 AM
Brew Master
cabmandone's Avatar
If you're running rich enough to have raw gas in the exhaust, you'd have a terrible stumble in the engine. Pull the plugs and look at them.
Nick
Old 04-17-2021, 03:15 PM
Crotchety Old Bastard
RarlyL8's Avatar
How long are you letting it run?
Old 04-17-2021, 07:30 PM
Bucketlist's Avatar
When I purchased my Turbo it was running good but extremely rich. The main indicator of this was backfire from the muffler on most full throttle up-shifts.
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 04-18-2021, 05:22 AM
