Send a message via ICQ to AirJose
Door stop question
Hello from Georgia
a question for the experts/gurus out there...
1986 doors on a 1969 body. Doors are installed and now I notice that the 1986 door stops are quite different from the 69 ones. The body has a solid tab!
Can the 1986 be used? (have 3) or do I need to locate part 901-531-035-20?
Thanks in advance and stay safe!
Jose
Old 08-08-2020, 08:51 PM
...ok guys, any ideas? Has anyone done it? guesses?
Old 08-09-2020, 05:19 PM
Maybe use '69 units? The bolt spacing is narrower than the later ones, so elongating the door mount holes is necessary.
206 637 4071
Old 08-09-2020, 05:30 PM
Thank you John. Will try that!
Old 08-10-2020, 05:12 AM
Try using a larger OD washer to support the mounting area in the door. That area is prone to cracking and worse.
206 637 4071
Old 08-10-2020, 09:50 AM
Does anyone have a guide for which door stop is correct for which MY?
Specifically, I am looking for what the factory would have used in mid 1973. I know it is not the current yellow cad units sold. Thank you for your help
Old 04-15-2021, 05:18 PM
