Deck Lid Strut
Looks like I have only one Deck Lid Strut. Its worn out! ...located on the driver side. this seem right? Which should I buy to replace? I now have a spoiler but may go back to a lid without it. Is there a strut that is good for with and without the spoiler?
that would be correct for the original engine cover. non-spoiler cars only had a single strut on the left hand side. spoiler cars had 2 struts, one on each side. not sure what to say about a single strut option to hold a spoiler deck lid. hopefully someone else will chime in here with a solution.
I dont see a fitting for another strut.
thanks |
There are a number of options and solutions. Check out the new Rennline offering.
Ass-engine Nazi slot car -- PJ O'Rourke |
have you tried the Rennline Mechanical Deck lid Strut? Is ONE STRUT going to hold a heavy lid AND not cause a problem with a light lid?...may go with and without spoiler to time to time.
I have not. Are you trying to use the same strut for 2 different weight lids? A mechanical strut or 2 is probably the best solution. A single gas strut likely won’t support the heavier lid and 2 gas struts may be a bit much for the lighter.
As noted, non-tail cars came with one strut on the left side. The right side hinge has no provisions for a strut. However, the clips for a right side strut should be on the firewall. So, on the advice of Draco, I found a right side deck lid hinge from a turbo car on ebay. This has a triangular bracket for strut attachment. I swapped this out for the factory hinge and installed stabilus heavy duty shocks on each side. Works perfectly. Remember it's not only the weight of the tail but also the A/C condenser they support. Should be no problem with tail removed, as the people who have issues are the ones who put to much on one side which causes the deck lid to twist. Even force should be good either way.
Here's my $0.02 -
The gas-struts are junk, all of them. The market is dominated by one supplier globally who makes a ton (or is that tonne) of them, and while *nothing* is supposed to last forever, this application is subject to a LOT more heat ("air-cooled") which is the enemy to the natural gas law (Pv=nRT), and also: with the "one side mount" solution, the strut will try to push the left side up a bit even while the lid is closed: making for alignment issues. I installed the (expensive, IMO) Rennline mechanical strut, which will not cause the alignment issue like the gas strut can. All said: spring for the Rennline one (our host has for about $75 + shipping) and you can switch your tail/no-tail as much as you'd like and you don't have to worry about installing a new strut. +1 for the rennline solution.
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things. |
'86 Targa (Mighty Mouse) '11 997.2 Carrera S Coupe (To be named) 08 M3 - Sold "Having a sports car that you only take to car shows is like having a race horse you only take to the petting zoo" |
I installed the Rennline mechanical strut on my fiberglass deck lid and am very satisfied with it, eliminated most all the misalignment. I do all my own service work but if the occasion ever arose where I needed to have work done, I would likely disconnect one end. Not sure the mechanic would remember to lift to close.
Walt 82SC 3.0 81SC 3.6 |
Said many a 356 owner.
My struts need replaced, and I think the Rennline is a perfect solution, but I saw a rumpled hood on a 356 last month that gives me some pause...
Yup. Mine came with a case of "gas station attendent-itis" as it's called.
Old dog....new tricks..... |
I replaced gas strut with renlline mechanixal and its ideal..even in cold weather i dont fear a bang on the head anymore
I mounted two struts when I added the tail decklid on my Targa. I just used some extra hardware of two 1.25" (maybe 1.5"?) long machine screws with some extra nuts for spacing the two struts. Once I pull the release, I still have to lift the decklid to assist in up, but I have no problems with it sagging or dropping once open.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
It should be noted that much of the time, the struts are installed incorrectly which will shorten their life, such as in all the pictures above. The correct orientation is with the piston pointing down when the decklid is in the closed position, allowing the oil inside to keep the rubber piston ring lubricated, retaining the nitrogen gas inside from leaking. In the case of the rear decklid, when closed, the strut tilts downward towards the firewall, so the piston end should face towards the firewall.
https://www.stabilus.com/service-spare-parts/installation-hints-and-tips/?popup=940 |
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
Still here
How about a stick or PVC pipe of suitable length ? That's what I use. |
BTW...there are at least 2-3 additional existing threads on these hood struts.
Just do a search and type in "hood struts". It's a popular topic and those old threads seem to cover it all just about.
| Tags |
| deck lid , lid , spoiler , strut , tail |
