What fuses are in Fuse Box III?
As shown in this picture, my '86 911 turbo has had some HOT wires going to this fuse set. I'm looking for a description of what those 3 fuses control, so I can find out what is going on.
I'm wondering if the old style fuses in the fuse block have such poor connectivity that they cause the heat?
1986 911 turbo - less than 30k miles
Old 04-16-2021, 06:34 AM
aj88cab's Avatar
The top fuse with the two wires is probably for the engine blower, but the diagrams I have seen indicate the middle fuse is for the engine blower. The engine blower is a 25A fuse, and definitely has a two wire feed.
So in this case the middle fuse appears to be the footwell blowers (0,1,2 speeds if manual). The high speed (#3) is feed from the front trunk fuse panel. It should be a 16A fuse here & 25A at the front.
You should trace the circuits to be sure, but possibly the top & middle fuses were switched during a repair or something, or that's the way the Turbos were done..
Both of these would run through the fan controller module on that same relay rack, silver box visible to the right in your picture.
The bottom fuse is rear window defogger & wiper.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 04-16-2021, 07:06 AM
Thanks!
I replaced the portions of the wires that were black, partially for cosmetic reasons. I'll watch them when I get the engine back in.
None of those things are important to me, so if they get hot again, I will be pulling the fuses.
terry
Old 04-16-2021, 07:46 AM
aj88cab's Avatar
As those fans age they start pulling more current, so it might be an indication the fans are on their last leg. Porsche added in-line fuses at the individual footwell blowers in 1987 (maybe '88) to protect against just this kind of issue.
Old 04-16-2021, 08:01 AM
Turbos don't have engine fans.
206 637 4071
Old 04-16-2021, 08:47 AM
aj88cab's Avatar
Thanks John!
And that is my "learned something new today" lesson
Old 04-16-2021, 08:53 AM
