Walt Fricke's Avatar
Who made this valve grinding machine?
I purchased a Snap-on valve grinding machine from a shop which was closing. I can find no model information on it. The information on the motor just covers the GE motor.
I am suspecting that Snap-on machines of this size are made by someone else, but don't know.
What I am looking for is a manual.
And what I need a manual for is to help figure out why the oil pump isn't squirting oil.
So I can grind my 911 valves, of course.
Walt
Old 11-05-2009, 09:31 PM
HarryD's Avatar
Walt,
Maybe this guy can help you out - Snap On / KO Lee VR200 & VR300 Valve Grinder Manual
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-05-2009, 10:10 PM
Harry
I saw that when Googling (and it caused me to suspect Snap-On put their brand on something also sold under another name by its maker), but the picture doesn't match up. I suppose I could contact the guy, though, to ask my question. He's got to know more than I do.
Walt
Old 11-05-2009, 11:17 PM
Steve F's Avatar
Just a guess but maybe it's a Sioux?
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 11-06-2009, 05:21 AM
That valve grinder is a Quik Way VS. I have one and its one of the best and most accurate valve grinders you will find.
Dom
1985 Black 911 Targa (Sold)
2007 Chev Malibu SS (wifey's car)
Old 11-06-2009, 05:25 AM
Walt, after taking a closer look at your picture and my valve grinder, your machine is probably a Quik-Way SV model not a VS model which is only slightly different.
I have a manual for your machine (SV) but in looking at it I'm not sure it will tell you what you want to know. If your interested, I'd be willing to mail my manual to you so you can make photocopies of it, then just mail it back.
Have you checked to see if the pump motor runs when you turn the switch on? The switch is a three way (on/off/on) and the pump should run when the switch is in both the far left and far right positions. If the pump is running and nothing is coming out of the valves over both grinding wheels you should see bubbles in the oil around the pump. Also, make sure the valves are open fully above the grinding wheels. BTI, the inside of the oil valves can become clogged with fine grinding grit and should be taken apart and cleaned.
Hope this helps.
Dom
Old 11-06-2009, 06:56 AM
304065's Avatar
see ebay 280417382317
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-06-2009, 06:57 AM
looking for a collet for a vr200 valve grinder
Old 04-18-2021, 09:04 PM
