AASCO motorsport flywheel size
Gentlemen please educate me on following:
got a RSR style 9 bolt flywheel from rebel s racing (made by AASCO) a while ago, but only today had a chance to install it and failed. I have a 911 sc 1982 with stock 915 gearbox and lightweight sachs pressure plate, but apparently the RSR flywheel a tad bigger in diameter than the original one and doesn`t fit. 275mm old vs 277mm new
Numbers on the flywheel I have are: 106407-12 and 1311.
So the question is - what the hell do I have?
Here is a pic of mine. just in case
Old 04-18-2021, 02:01 AM
Bill Verburg's Avatar
looks like maybe for a 240mm clutch ala G50 and 930
915 uses a 225mm clutch
Bill Verburg
Old 04-18-2021, 05:43 AM
Yes, probably 930. Here is a 915 flywheel. Note flywheel is inside of of case where yours stick out past bellhousing register.
Old 04-18-2021, 06:21 AM
BURN-BROS's Avatar
The OD appears to be outside of the transmission register....I have never seen a 911, turbo or otherwise at that dimension. I would call Aasco on Monday and get solid info.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 04-18-2021, 02:41 PM
Thank you gents, I have wrote them an email, waiting for the response. Hope it`s for a Porsche )
Old 04-19-2021, 12:46 AM
(man/dude)
Jonny042's Avatar
If you sent an email to Rebel you might want to try contacting Aasco directly..... just sayin'
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 04-19-2021, 04:47 AM
Haha nah, you know I read this forum like a lot so, I know the drill with Clint )) Will try to contact him just in case...
Anyway, got the answer from AASCO saying it is 80-88 3.3 935 (whatever they mean) big bore flywheel for 240mm PP and was produced back in 2013.
Well, seems like I`m stuck with this one for a while...
Old 04-20-2021, 01:15 AM
(man/dude)
Jonny042's Avatar
Oh crap!! I just noticed you're in Australia..... no such thing as an easy return. And you'll never get your shipping, taxes, exchange fees, etc. back, even if it was no fault of your own and you were shipped the wrong one.
Old 04-20-2021, 03:36 AM
356RS's Avatar
Good eye Aaron......
Mark Jung
Bend, OR
MFI Werks.com
Old 04-20-2021, 05:30 AM
