Twin Turbo Header Design
Hey guys, I've officially started the project. I pulled the motor today, took some measurements, and came up with this design for the custom headers I will be making for the twin turbos. What do ya think?
http://forums.pelicanparts.com/uploads/F1a.jpg http://forums.pelicanparts.com/uploads/F2b.jpg http://forums.pelicanparts.com/uploads/F3b.jpg |
Looks cool Mark,
Just had a look at your site, can't believe what you've done! Nice one! Cheers |
It looks good, my only worry would be that it looks very close to the heads and there might be some heat transfer. Which is the cheapest CAD software I can get?
Where do you get your tubing from? It looks like it is in a tighter radius than I can get.
are you going to be able to adjust valves without pulling the exhaust manifolds?
and i too LOVE your old setup......can't wait to see the new :D |
Have you considered hanging them out back, 935 style?
Those things get very, very hot. |
Thanks all,
Boost, I plan on making het shield to address heat soak issues. The cheapest CAD softwre you can get is free. The program I am using here is ProDeskTop Express, you can down load it at www.ptc.com. Blown, I am getting my tubing from SPD products 888/778-3312, they have a huge selection. The tubes you see are 2" CLR. Bell, I will have to drop the headers to adjust valves. Ohhh the price we pay for addictions. Axix, I did consider mounting them in the back. It just doesn't leave any room for exhaust. |
Natchamp,
The design looks great. I'm jealous of your fabrication skills in putting the pipes together. I would suggest routing the pipes a little further out from the cyl. head area as IMONBOOST recommends (to reduce heat soak) and to make valve adjustment a little less service-intensive. Dropping the exhaust system means dealing with broken exhaust manifold studs. I also realize being an armchair designer is much easier than redrawing/redesigning, so take this with a grain of salt. To save time in fabricating an effective heat shield, provide about 1.25" of space in front of the valve cover for a set of these (commercial plug). Sherwood Lee http://members.rennlist.org/911pcars |
Natchamp,
The design looks great. I'm envious of your fabrication skills in putting the pipes together. I would suggest routing the pipes a little further out from the cyl. head area as IMONBOOST recommends (to reduce heat soak) and to make valve adjustment a little less service-intensive. Dropping the exhaust system means dealing with potential broken exhaust manifold studs. I also realize being an armchair designer is much easier than redrawing/redesigning, so take this with a grain of salt. To save time in fabricating an effective heat shield, you can provide about 1.25" of space in front of the valve cover for a set of these (commercial plug). Sherwood Lee http://members.rennlist.org/911pcars |
| All times are GMT -8. The time now is 09:23 AM. |
