Senior Member
Natchamp's Avatar
Twin Turbo Header Design
Hey guys, I've officially started the project. I pulled the motor today, took some measurements, and came up with this design for the custom headers I will be making for the twin turbos. What do ya think?
Mark
The Beast
mark@hargett.com
www.HargettPrecision.com
Old 05-02-2003, 11:17 PM
AirCooledExcellence's Avatar
Looks cool Mark,
Just had a look at your site, can't believe what you've done! Nice one!
Cheers
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD
1987 930 - SOLD
1983 911 SC Targa - SOLD
http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else
Old 05-03-2003, 02:39 AM
Got Boost?
IMONBOOST's Avatar
It looks good, my only worry would be that it looks very close to the heads and there might be some heat transfer. Which is the cheapest CAD software I can get?
"The only motivation to make you go race after race, travel after travel, is winning. The possibility that you have for winning. If you don't have that, nothing else can make you work."
-Ayrton Senna-
Old 05-03-2003, 04:15 AM
Where do you get your tubing from? It looks like it is in a tighter radius than I can get.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 05-03-2003, 05:42 AM
one of gods prototypes
bell's Avatar
are you going to be able to adjust valves without pulling the exhaust manifolds?
and i too LOVE your old setup......can't wait to see the new
Brought to you by Carl's Jr.
Old 05-03-2003, 06:52 AM
Have you considered hanging them out back, 935 style?
Those things get very, very hot.
Old 05-03-2003, 08:12 AM
Senior Member
Natchamp's Avatar
Thanks all,
Boost, I plan on making het shield to address heat soak issues. The cheapest CAD softwre you can get is free. The program I am using here is ProDeskTop Express, you can down load it at www.ptc.com.
Blown, I am getting my tubing from SPD products 888/778-3312, they have a huge selection. The tubes you see are 2" CLR.
Bell, I will have to drop the headers to adjust valves. Ohhh the price we pay for addictions.
Axix, I did consider mounting them in the back. It just doesn't leave any room for exhaust.
Mark
The Beast
mark@hargett.com
Old 05-03-2003, 09:14 AM
Natchamp,
The design looks great. I'm jealous of your fabrication skills in putting the pipes together. I would suggest routing the pipes a little further out from the cyl. head area as IMONBOOST recommends (to reduce heat soak) and to make valve adjustment a little less service-intensive. Dropping the exhaust system means dealing with broken exhaust manifold studs. I also realize being an armchair designer is much easier than redrawing/redesigning, so take this with a grain of salt.
To save time in fabricating an effective heat shield, provide about 1.25" of space in front of the valve cover for a set of these (commercial plug).
Sherwood Lee
http://members.rennlist.org/911pcars
Old 05-03-2003, 10:46 AM
Natchamp,
The design looks great. I'm envious of your fabrication skills in putting the pipes together. I would suggest routing the pipes a little further out from the cyl. head area as IMONBOOST recommends (to reduce heat soak) and to make valve adjustment a little less service-intensive. Dropping the exhaust system means dealing with potential broken exhaust manifold studs. I also realize being an armchair designer is much easier than redrawing/redesigning, so take this with a grain of salt.
To save time in fabricating an effective heat shield, you can provide about 1.25" of space in front of the valve cover for a set of these (commercial plug).
Sherwood Lee
Old 05-03-2003, 10:54 AM
