Oil pressure warning light
1972 911.
My oil pressure warning light does not illuminate at all. I replaced the bulb and that did not solve the issue. I also bridged the two wires from the switch and it did not light up. I had my gauges out to be restored so I want to check that I have the correct wires running to the warning light bulb and didn’t run the wrong wires when I put the gauges back in.
The bulb has 2 brown wires on a piggyback spade and a black and white wire with a green stripe running to the other spade. Here are some photos.
Old 05-08-2021, 12:13 PM
Here is a closeup of the wire that is black/white with green stripe
Old 05-08-2021, 12:15 PM
Well - never mind. I think I figured it out. That top light on my gauge isn’t oil pressure - it is the e-brake and brake failure light. I have driven this car very little after a long restoration and am still getting familiar with it!
Old 05-08-2021, 12:35 PM
wire
Green with red for oil pressure I believe.I will check my 72 later after the lawn cutting.
ROW '78 911 Targa
timmy2's Avatar
Green/Red is oil pressure signal wire to gauge.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-08-2021, 12:47 PM
Thanks guys. Yes, oil pressure gauge works perfect. Just what I thought was the warning/idiot light. I think I’m good now.
Old 05-08-2021, 01:08 PM
