Modern Entertainment for the 911
Hey guys-Happy Friday!
Just wondering if folks could share what they have done to modernize their car's entertainment systems. I am not looking to keep things classic (old syle head unit etc). I don't want to cut extra holes and add massive amps and 4 gauge wiring either.
I am more looking for a head unit that does Bluetooth, etc to modernize the system. I also plan on updating the speakers without changing mounts or cut-outs.
I have an 88 Coupe if that helps...
Let me know what you have done, what you like, tips tricks and such that you might share.
Thanks!
Old 05-21-2021, 08:59 AM
That's fond- just deglaze
Hi thsupernge- The SQR46 DAB string might be helpful, however, you would still retain the classic look. (not sure if that's important based on your post)
New Blaupunkt Black Radio Avail 2018
Hope this helps!
Missed Approach
Petra- 1986 Coupe
Old 05-21-2021, 10:23 AM
Awesome, I will look it over! TY!
Old 05-21-2021, 11:51 AM
911SC Tinkerer
merlinfe's Avatar
If I were to do this again I’d add a phone mount.
Radio Delete / Hidden Audio install
Old 05-21-2021, 12:08 PM
there are some good threads out there on speakers/mounts, etc. search the forum for "focal" and "morel" for some examples. I'm a big fan of the 911-specific rennline iPhone mount, think great sound can be had with a combo of door speakers and an underseat subwoofer (powered by an external amp) --
Old 05-21-2021, 12:12 PM
Perfect! Do you have any brand recommendations on speakers you like?
Old 05-21-2021, 01:05 PM
I installed a sony Mex#### i dont remember the model # it does 2 bluetooth connections the LEDs are programmable colors so you can match the intensity and color of dash lights. Not too much bling, used Focal speakers in front work nice
Rear speakers need spacers or aftermarket covers if using coax.
Old 05-21-2021, 01:08 PM
Most modern stereos use independent grounds for the speakers so new wires need to be run.
Old 05-21-2021, 01:10 PM
So stock are ground via the speaker base and new have a separate lead? Can that lead be ground to the door.
Old 05-21-2021, 01:24 PM
“Just wondering if folks could share what they have done to modernize their car's entertainment systems”
Certainly - I have removed the radio + loadspeakers from my 911
You drive one of the best sounding cars, and then you want music !
Old 05-21-2021, 01:27 PM
Mark Salvetti's Avatar
In case folks didn't see the sale, the Rennline phone mount is 20% off through May 31 with our host.
Mark
1979 911SC Targa
Old 05-21-2021, 02:02 PM
(man/dude)
Jonny042's Avatar
Blaupunkt SQR-46..... it's a wonderful unit.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 05-21-2021, 03:13 PM
Awesome, I will check it out. Much appreciated!
Old 05-21-2021, 03:18 PM
speakers, have heard good things about focals and morels for our cars -- My setup's currently VERY minimalistic -- use my iPhone as the source, feeding a bluetooth>RCA interlace that's wired into an old 2 channel a/d/s amp under my passenger seat. Next steps include 1) adding a powered sub under passenger seat - focal IBUS 20 or 2.1 look interesting, 2) replacing my dead in-dash radio with the Blaupunkt Bremen referenced above (probably stick with the a/d/s amp, as it sounds nice, 3) properly mounting my door speakers (probably start with my speakers and potentially upgrade later?) to the metal door panels (there are threads about how to do this with a cutting board - I have some plastic cutouts I bought from a (now defunct?) vendor that used to be on this forum - and deadening the doors with dynamat/etc.
Old 05-21-2021, 03:44 PM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
My approach is a bit different.
Some time ago I replaced the original head unit with a CDR-220, also replacing the door and rear deck speakers but keeping the stock-style speaker grills.
I then sold the CDR-220 and reinstalled the original Blaupunkt SQR26 because I wanted the original look, someone wanted to buy the CDR-220, and because the original unit sounds pretty darn good. My logic is that my '87 Carrera will never have the "concert hall" sound of my much newer daily driver (which has 450w, 12 speakers, logic 7 surround sound, etc.) and I would have to add lots of acoustic insulation if I was to try.
To adapt the original head unit to "modern audio", I got both wired and Bluetooth cassette adapters (Sony CPA-9 & Ion Cassette Bluetooth Adapter) so I can interface with my iPhone. For the iPhone, I made a removable adapter that tightly fits into the ash tray and provide a location for a "vent" type phone holder.
And yes, that is Miles Davis "Kind of Blue" playing on the iPhone. After all, Blaupunkt translates to "blue dot" and the previous posts displayed "turn blue".
Old 05-23-2021, 01:28 PM
Speakers have come a long way in the past 20-30 years. A set of good quality modern speakers and a head unit to power them (or an amp) will sound much improved. Add to that your choice of wired or wireless connectivity and you can maintain OEM looks with modern features and sound you can hear clearly at freeway speeds and above.
Brian Miller - Scottsdale, AZ
1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 05-23-2021, 04:49 PM
I have installed this VDO/Continental in my 85 Carrera 3.2 and am very happy with it.
https://www.ecstuning.com/b-vdo-parts/radio-orange-display-usb-mp3-wma-12v-vdo/tr7412ub-or~con/?gclid=CjwKCAjw-qeFBhAsEiwA2G7Nl92b2fwTQWqibVRfuGmQGs2r1zS2zRkfhKU 1xsp80o0gIKW9EOKQYRoCi_QQAvD_BwE
Its not fancy, but it does have bluetooth that works well, and hands free also. I upgraded the speakers under the 80s alpine speaker grilles in my car. Just to some regular quality ones and the stereo is good, but not amazing. A sub under the seat would help.
Cheers
Stewart
1985 Porsche 911 Carrera 3.2 Coupe - Iris Blue
Old 05-23-2021, 07:08 PM
In addition to the VDO/Continental, the Clarion M508 is a nice option.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 05-24-2021, 06:17 AM
