New Manufacture of Aluminum S Calipers
I saw these on ebay, and at CarPoint in Germany. Anyone have any experience with them wrt quality? They're not brand marked, so who knows who makes them. China?
https://www.ebay.com/itm/Porsche-911-T-S-Rs-Turbo-Aluminium-Brake-Calipers-Calippers-91135193500/161484871788?hash=item25993f986c:g:I10AAOSwNSxVgDQ k
Dave
1969 911T Coupe
1972 911E Targa
Old 04-19-2021, 01:12 PM
Titanium User
Tried to buy a set through Sierra - backordered indefinitely they told me, so I ended up buying new SC calipers for an early hotrod.
Buy some Titanium Lug Nuts!
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html
ig: @ti_porsche_products
Old 04-19-2021, 02:02 PM
Uncertifiable!!!
Uwon's Avatar
Did you replace all or just the front? Did you upgrade the master?
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 04-20-2021, 05:19 AM
Titanium User
Johan
Rears, I just rebuilt are factory early steel ones (M Calipers). Didn't upgrade the master, the front SC use the same pads/rotors as early S calipers. I sent out a set of early S calipers to get rebuilt/replated and after 2 tries they got stuck each time. I'm not sure what my issue was so I got tired and just ditched them. Went with a set of brand new SC front calipers.
Old 04-20-2021, 06:19 AM
(man/dude)
Jonny042's Avatar
They are made by Dansk/JP Groups. I have them on my "Project Heavy Metal":
Dimensionally and from a piston size standpoint they are the same as SC calipers, and conveniently use a standard SC/Carrera pad thickness rather than a much harder to find thicker "S" pad.
With these there is no need to upgrade the master cylinder since the piston sizes are the same as every 911 since 1969 (I think).
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 04-20-2021, 06:56 AM
(man/dude)
Jonny042's Avatar
I was unable to find a source for the brake lines for these (74-77 911S with the "S" caliper, NLA from what I can tell) so had to make my own. Also, just like everything you buy these days, a purchase wouldn't be complete without some sort of annoyance..... I also bout new rear calipers at the same time and had to remove and re-clock the caliper pistons in all 4 calipers so they were properly oriented.
Old 04-20-2021, 07:05 AM
anyone else?
Dave
1969 911T Coupe
1972 911E Targa
Old 04-21-2021, 08:12 AM
(man/dude)
Jonny042's Avatar
These show a 90mm hole spacing - were the original "S" calipers on the longhood cars 3" or 3-1/2" spacing?
Old 04-21-2021, 10:05 AM
I would rather be driving
jpnovak's Avatar
3.5" on early S Al calipers.
Now, if there is a 3" version that would bolt on that would be nice. Even better if it took a Carrera 24mm rotor.
Old 04-21-2021, 10:35 AM
Northern Motorhead
wildcat077's Avatar
Jonny,
That looks like a nice restoration you're doing !
Sooooo clean ...
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 04-21-2021, 11:42 AM
(man/dude)
Jonny042's Avatar
Originally Posted by wildcat077 View Post
Jonny,
Sooooo clean ...
Thanks!!! It's a good read (if I don't say so myself...), pour yourself a beverage first!!
Project Heavy Metal - an all steel classic, remastered
Old 04-21-2021, 05:00 PM
