-   -   Lubricant for Reinstalling Injectors (http://forums.pelicanparts.com/porsche-911-technical-forum/1091611-lubricant-reinstalling-injectors.html)
isby 04-21-2021 02:54 PM
What say you all re: lubricant that should be used on injector o-rings when reinstalling in a 3.2 Carrera? Silicone paste? Molykote? Other? Thanks!
proporsche 04-21-2021 02:59 PM
Sachs lubricant works the best
https://aftermarket.zf.com/remotemedia/migrated/services/workshop-service/import-brands/technology-in-practice-1/fatcushion-tube-zoom-zf_w960.jpg?v=101070070
isby 04-21-2021 03:05 PM
Much appreciated. Appears to be available from our host and so I'll pick up a tube.
john walker's workshop 04-21-2021 03:23 PM
Silicone paste, just a light smear.
stlrj 04-21-2021 05:50 PM
WD40 works for me.
theiceman 04-21-2021 06:05 PM
silicone paste. manual just says soak them in gas..
jjeffries 04-22-2021 03:19 AM
WD40, synthetic grease, KY, olive oil, dish soap ... whatever you have kicking around.
John
Flojo 04-22-2021 04:07 AM
dish soap. always at hand, for sure doesn't attack rubber, vanishes by itself
walt 04-22-2021 04:33 AM
All of the above plus Dow 111 specifically made as an o-ring lube. You can find small tins of this online for not to much $$.
jlex 04-22-2021 05:00 AM
But isn't silicone supposed to be harmful to sensors? O2 sensor maybe? Ordinary grease may be the safer alternative.
Mike Andrew 04-22-2021 05:09 AM
I soaked mine in gas per the manual and they went in with no issues.
I think any of the suggestions above will work just fine.
isby 05-10-2021 09:32 AM
Got my '84 3.2L injectors back from RC Fuel Injection - the report is pretty interesting (although -- for some reason -- my wife did not find it nearly as interesting as I did -- go figure). It clearly shows that the injectors were sorely in need of service:
http://forums.pelicanparts.com/uploa...1620664186.png
My question to the group is, once the injectors and rails are re-installed, is there a start-up protocol that should be followed given all the air in the fuel system? Or do you just crank it until it fires up?
cabmandone 05-10-2021 09:41 AM
When I put mine in after cleaning I just hit the key. Don't know if that's right or wrong but it worked. Now, I'd probably wait a few seconds since my car has a tune that runs the pump for a few seconds to prime the system. If you really want you could install the injectors and put a jumper on the fuel pump fuse to run the pump for a few seconds and prime.
To your original question, I think I used some Sil glyde when I installed my injectors.
BTW, I don't know why wives don't find that stuff as interesting as we do. :confused:
pmax 05-10-2021 10:57 AM
Whew, good to know ... cause that’s what I used on the CIS injectors.
