Lubricant for Reinstalling Injectors
What say you all re: lubricant that should be used on injector o-rings when reinstalling in a 3.2 Carrera? Silicone paste? Molykote? Other? Thanks!
Sachs lubricant works the best
https://aftermarket.zf.com/remotemedia/migrated/services/workshop-service/import-brands/technology-in-practice-1/fatcushion-tube-zoom-zf_w960.jpg?v=101070070
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Much appreciated. Appears to be available from our host and so I'll pick up a tube.
Silicone paste, just a light smear.
WD40 works for me.
silicone paste. manual just says soak them in gas..
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
WD40, synthetic grease, KY, olive oil, dish soap ... whatever you have kicking around.
John |
dish soap. always at hand, for sure doesn't attack rubber, vanishes by itself
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
All of the above plus Dow 111 specifically made as an o-ring lube. You can find small tins of this online for not to much $$.
Walt 82SC 3.0 81SC 3.6 |
But isn't silicone supposed to be harmful to sensors? O2 sensor maybe? Ordinary grease may be the safer alternative.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
Wildman Emeritus
I soaked mine in gas per the manual and they went in with no issues.
I think any of the suggestions above will work just fine.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
Got my '84 3.2L injectors back from RC Fuel Injection - the report is pretty interesting (although -- for some reason -- my wife did not find it nearly as interesting as I did -- go figure). It clearly shows that the injectors were sorely in need of service:
![]() My question to the group is, once the injectors and rails are re-installed, is there a start-up protocol that should be followed given all the air in the fuel system? Or do you just crank it until it fires up? |
Brew Master
When I put mine in after cleaning I just hit the key. Don't know if that's right or wrong but it worked. Now, I'd probably wait a few seconds since my car has a tune that runs the pump for a few seconds to prime the system. If you really want you could install the injectors and put a jumper on the fuel pump fuse to run the pump for a few seconds and prime.
To your original question, I think I used some Sil glyde when I installed my injectors. BTW, I don't know why wives don't find that stuff as interesting as we do.
Nick Last edited by cabmandone; 05-10-2021 at 09:44 AM.. |
Still here
Whew, good to know ... cause that’s what I used on the CIS injectors.
