Oil leaking from R/H Timing Chain Housing on Heat Exchanger
I have an oil leak that seems to be coming from the R/H timing chain housing. Its leaking on the heat exchanger. The engine is a 3.2. I've installed RSR rocker arm shaft seals on the #4 cylinder exhaust rocker arm shaft but its still leaking. What other leaks could I be having in this area? Any help would be appreciated.
Old 04-21-2021, 02:48 PM
proporsche's Avatar
it is you your camshaft cover gasket and o ring leaking
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 04-21-2021, 02:55 PM
Doesn't seem to be.
Old 04-21-2021, 03:01 PM
Witch o ring are you referring to?
Old 04-21-2021, 03:11 PM
proporsche's Avatar
it is this one...it is clearly leaking down on the body of the chain housing...
it is.... 1 and 2
this one
Old 04-21-2021, 03:31 PM
I haven't taken the cover off. But it is leaking at a steady pace out from what looks like the housing as pointed to in the picture.
Old 04-21-2021, 04:06 PM
If it is one of these can I take the cam gear off and the chain not slip off the crankshaft causing it to come out of time?
Old 04-21-2021, 04:29 PM
You are going to wind up having to re-time that camshaft. You can make your life easier by making sure that the right hand camshaft is in its timing position - TDC on #4 - prior to removing the sprocket. Lots of folks will try to tell you that you need to loosen up the rocker arms so the camshaft doesn't want to snap over out of time, but I have found I have never had to do this. In other words, you can time the camshaft with all of the rockers still in adjustment. This is not a difficult job in the least, but you do need to have an understanding of what is going on, and why. And the right tools...
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 04-21-2021, 08:11 PM
proporsche identified this leak for me on my 1978SC. You need to remove the camshaft nut to get at the seals and be careful not to lose the timing. I bought the Stomski cam tool to do the job, much better than the crow's foot tool. Also good to have a dial gauge to check that timing is correct before and after cam nut removal. The job can be done with the engine in the car, at least that's what I did.
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 04-22-2021, 12:02 AM
proporsche's Avatar
the last thing before you get to this double check you alu.seal on right side camshaft fitting here.....marked with black arrow,you might be lucky ...but generally this is a sign of camshaft cover o ring and gasket
Old 04-22-2021, 12:24 AM
Thanks All!
Old 04-22-2021, 02:08 AM
Although it's not your issue your valve covers seems to be over tightened causing the gasket to be squeezed out.
Old 04-22-2021, 06:24 AM
Agree.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 04-22-2021, 06:45 AM
I torqued them to 6 ft-lbs.
Old 04-22-2021, 02:25 PM
I just went through the cam cover gasket change. If you know what you are doing with cams that is great. If not, you should get someone who knows what they are doing. It is not a simple gasket change.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 04-23-2021, 03:58 AM
