3.2 No Start but sensors check okay. Advice Requested
Last Fall, I was having some issues with an intermittent no start. I ended up finding a badly cracked/epoxied reference sensor connector. Since I was pulling the engine for a transmission rebuild anyway, I replaced the crank and CHT sensors, and repaired the harness side by installing a new JPT connector.
With the engine now back in the car, I still have a "cranks, but no start" condition with a known good DME relay. Car starts and runs fine with a 30/87/87b DME relay jumper. Here are the checks I have done thus far. Checked at the DME Connector 1. CHT Sensor - 2.57K ohms - OK 2. Speed Sensor - 993 ohms / 2.8VAC - OK 3. Reference Sensor - 985 ohm / 0.5VAC - OK 4. Pins 5/16/17 are all good grounds - OK 5. Pin 1 - 12V - OK *This seems to suggest that my repairs and sensor replacement were successful. Checked at the DME Relay Connector 1. Pin 30 - 12V - OK 2. Pin 86 - only 4-6 volts with key in Run - Seems sketchy. I do have the factory alarm, but it was jumpered out long ago using the information here on Pelican. (I'm beginning to wonder if possibly the contacts in the ignition switch are failing) What have I missed, and where would you suggest I look next? Thanks!
1984 M491 Coupe 2014 Cayman S Last edited by Quasimoto; 04-24-2021 at 01:52 PM.. |
Brew Master
Wow! If it runs with the jumper it should run with the good DME relay installed unless for some reason you're not getting power to the coil of the DME relay. If I'm not mistaken you're just closing the circuit with the jumper. If the relay isn't getting power to the coil, it will not start.
Nick |
I believe Pin 86 is power to the DME 1st stage relay coil from the key/alarm, and I don't have full voltage there.
Question is, where is the first place to look next?
1984 M491 Coupe 2014 Cayman S |
Brew Master
I don't know. I'd need to look at a wiring diagram and trace it. I think I have one on CD. If I get a chance I'll fire up one of my old laptops that have a CD drive and take a look. Hopefully someone will chime in. You might PM Steve Wong or Sal. Both can probably tell you off the top of their heads.
Nick |
Brew Master
Here ya go.
no 12v power to dme relay socket pin 86 And Here https://dorkiphus.net/porsche/showthread.php?t=16859
Nick |
I’d love to test that circuit after the ignition switch so I could be certain that’s the problem.
The schematic in the Bentley says that goes as Red/Blk to fuse 7 in the frunk, and from there a Blk/Red wire runs back to the alarm module, but I can’t find a fuse that matches the colors shown. |
Brew Master
Don't know how long the leads are on your meter but you could disconnect the batter, plug one into the ignition switch harness, and start hitting wires till ya get continuity.
Nick |
The DME relay then provides 12V power to pins 1, 18, & 35 of the DME ECM. For additional troubleshooting info, check here; 911 3.2 No-Start Troubleshooting
Dave |
Thanks @cabmando
On my car, the DME Relay pin 86 is fed from the factory Alarm module that is connected to the keyswitch. (It was jumpered out a couple of years ago) Since I have low voltage at the DME relay pin 86 and it fluctuates with the key operation a bit, I suspect that it's the contact in the ignition switch. I would like to confirm it by measuring it after the keyswitch but cannot seem to locate that wire on the fuse panel as it's shown on the diagram. Is it possible that my car being an 84 is different than the schematic I have for an 85, and this junction is made somewhere else?
Brew Master
At this point you know it's either fuse 7 or 8. I'm not following the difficulty at this point?? You could answer this question with a multimeter in about 10 minutes from here.
There are 6 25a fuses in the fuse box if I'm not mistaken. Even if you're not 100% sure which fuse is 7 or 8 this shouldn't be hard to figure out with a multimeter at this point.
Nick Last edited by cabmandone; 04-25-2021 at 05:23 AM.. |
No!
Dave |
That's good!
Brew Master
FWIW, my B.I.L and I fought a no start on a 914 with a Subie powerplant for probably 5 or 6 hours. I was convinced he had a crank position sensor problem. Ended up being his key switch which was only 2 years old. They fail.
Based on your other thread it looks like you're on the right path.
Nick |
I hope so. Decided to do the Hazard switch while I’m at it as it has a broken ear....yadda yadda yadda $250 bucks later, I have them coming Wednesday.
Brew Master
While yer in there strikes again! LOL
Nick |
And there was much rejoicing!!! Thanks to all that offered advice and encouragement!
We are back to freakishly fast starts, so seats are going back in today just in time for some really nice weekend weather. Interestingly, my troubleshooting was made a little more difficult because I could often read full voltage at all of my test points. I ended up opening a mechanical DME relay so I could see the coil movement, and using alligator clips to test the circuit. Even though I could read full voltage through the ignition switch contact with a meter, it would not pull in the stage 1 coil ...just wiggle it for a millisecond or so. Replacing the ignition contacts and the hazard switch were a little fiddly, but it’s done and I’m thankful that Pelican had them in stock and shipped them quickly for a reasonable fee... Edit: I think my desire for a Singer has evolved from mechanical lust to just wanting to be done with the dodgy under dash electrics on those cars...lol Last edited by Quasimoto; 04-30-2021 at 10:46 AM.. |
