El Duderino
Get it while you can…
Looks like R-134a and other refrigerants are going to be phased out…
https://www.npr.org/2021/05/03/993054374/epa-moves-to-cut-a-powerful-greenhouse-gas?ft=nprml&f=1007
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
Coram Deo
Great for refrigeration companies. Not so good for the rest of us.
What do they suggest we use instead?
Dru 1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter • 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio • |
Kind of Blue
Roll down the window, feel the warm air through your hair.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
El Duderino
Apparently, R-134a will not phased out the same way R-12 was eliminated, which was to restrict production. It appears R-134a will be economically starved out over the next decade or so. I don’t know anything about the 3 replacement refrigerants. Are they a direct replacement or do they require adaptation? Honeywell seems to say 1234yf is a drop-in replacement with the same characteristics and no adaptations required. https://www.honeywell-refrigerants.com/india/wp-content/uploads/2013/03/honeywell-solstice-hfo1234yf-atlas-copco-case-study.pdf
El Duderino
According to this article…
https://www.underhoodservice.com/is-a-new-refrigerant-going-to-replace-r-134a/ …1234yf will require different service fittings, a different PAG oil and will not be available to DIYers.
And converting my SC to 134a is on the to-do list! I guess I go ahead and get it done.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
I'm going the other way. I bought a 30 pound jug of R12 so I'm going to convert back to R12. Since I was getting "acceptable" cooling due to all the Griffith's upgrades, I should have even better results with R12.
Be sure you have installed the modern barrier hoses to prevent the flow loss of you R12. Also. Be sure your lubricant and compressor are compatible.
I will be working with Charlie at Griffith's to make sure I get everything right. |
Functionista
Funny thing is R12 was never eliminated as it’s the most efficient refrigerant for automotive use. Can be found with only a little effort. I’m sure R134a will be “eliminated” in the same way...
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
What about the days it is 100+ degrees and 90% humidity in Houston or Savannah? Drive to Key West, FL in the summer and tell me you don't want AC.
I will stick to my Air Conditioned nice cold car.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
My wife is happy to ride with me in the summer heat. We have been to 41 states in comfort, and plan to hit all 48 continental states in my 911.
El Duderino
What can be found is old stock. R12 hasn’t been made since the 1990’s.
Functionista
Not true. I got the certification and buy it in bulk regularly from HVAC supply stores. I will look for a date on container but it’s certainly not old stock.
Still here
Just saying ! But back on topic, looks like there's already a run on it, my order may be cancelled due to lack of stock. |
Red Tek works nicely.
El Duderino
R12 hasn’t been made internationally manufactured since 1996. It’s either old stock or reclaimed. R12 : Refrigerant Freon Refrigerants R12 Refrigerant Dayton Ohio
El Duderino
You live in the Bay Area. Your opinion doesn’t count. LOL
Functionista
![]() June 2015 in lower corner... Its been discontinued on paper only. Always been available and I don’t hear from my supplier that it ever will be...
R12 was about ozone depletion, the cause de jour of the 90s. R134 is about greenhouse gas, the current crisis de jour. The issue is that refrigerant gasses work because of specific properties around boiling points and densities. You can move that around with different pressures but ultimately you’re going to get a gas with measurable global warming potential.
Ultimately there is far too many r134 systems out there for it to go away any time soon, but stockpiling over time is a smart move. The people that govern you don’t like you and want you to stop enjoying yourself, because your pesky nonconformance ruins their spreadsheets. Progress in life requires making peace with this and adapting accordingly. |
