Master cylinder switch
Hi
After upgrading my master cylinder, I noticed the connection from the MC only have one prong and there 2 connections from the wire.. Did I put in a wrong switch? What is my option? I don't want to spend on new switch.
Bob
Old 05-06-2021, 02:34 PM
kfosburg's Avatar
Send a message via AIM to kfosburg Send a message via Yahoo to kfosburg
That's the same as mine. One of those two wires is sufficient - trial and error or look for witness mark on the connector.
Ignore the crusty underside:
Karl
Old 05-07-2021, 08:14 AM
Thank you Karl,
so just connect one wire and ignore the other. Just to sure, what is the "witness mark" on the connector?
Old 05-07-2021, 02:18 PM
Witness mark- the connector/female plug that has scratches or an imprint of the male plug as evidence of it being attached previously.
Old 05-07-2021, 02:33 PM
got it, so I would look for a mark indicating used on a male terminal from the switch previously..
Hopefully only one will show the mark and not both...but there a chance that both will show the mark say ...if both were used previously on a 2 prongs switch. I just have to check and see.
Thanks again
Old 05-07-2021, 02:47 PM
kfosburg's Avatar
What they said... There are 2 wire switches and single wire switches. You may have to trial and error it... 50/50 shot at getting it right first try.
Karl
Old 05-08-2021, 02:07 PM
Karl,
Just curious, what is the switch on the MC for? It's not for the back up light.. I don't think. Could it be an indicator light for one of the instrument gauge?
Old 05-09-2021, 08:32 AM
Bentley pg 470-9 > indicates it is the stop light switch
kgl
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 05-09-2021, 04:29 PM
