-   -   9" Fuchs on SC flared '69 Question (http://forums.pelicanparts.com/porsche-911-technical-forum/109348-9-fuchs-sc-flared-69-question.html)
Fishcop 05-04-2003 07:38 PM
It appears I am going to have to replace the 15" wheels on my car (DON'T EVER CHROME FUCHS).
I am probably going to go down the 16" route and am currently entertaining the idea of 9" rears (off a turbo).
Does anyone know if these will fit under my SC width arches or will I have to roll the lips or increase camber to get them to fit? Also what are the negatives of such large rims on what is an original 69 supension set up eg. bearings/cv's etc...?
Cheers
CamB 05-04-2003 07:52 PM
Can't speak for the second part, but there are definitely guys on the BBS with 16x9s. It is pretty tight though...
m325ix 05-04-2003 07:56 PM
I have lowered 82SC and 9x16 Turbo rims in the rear with 245/45/16 tires, no rubbing at all, my fenders are not rolled
911pcars 05-04-2003 08:04 PM
John,
I've got 9" Fuchs and 245/45-16 Yoko AVS plus on my '69 w/RS rear fenders (equiv. to your SC flares). No problem. As long as the offsets are not radical (they're not), there shouldn't be any issues with wheel bearing loads. What's going in the front? Front clearance is a little trickier with wider wheels/tires.
Sherwood
http://members.rennlist.org/911pcars
Fishcop 05-04-2003 08:36 PM
Fronts are to be 7" any problems there Sherwood?
Stuttgart951 05-04-2003 08:42 PM
They will fit. Last month's excellence had an early wheel base car with 9's mounted and no fender rolling IIRC.
Bottom line, SC/Carrera flares will accept 9 inch wheels with minimal difficulty.
Fishcop 05-04-2003 08:45 PM
Okay, thanks guys. Now to raid the piggy-bank!
911pcars 05-04-2003 08:51 PM
"Fronts are to be 7" any problems there..?"
If 16x7 and 205/50-16, it should be okay unless the vehicle height is low. Each car is slightly different. In addition. on some cars, the clearance gets tight between the tire and the front part of the wheel well (around 9 o'clock) - tight enough that a front end bra holddown strap might rub.
With 225/50-16, might have to trim the wheel well lip and watch ride height.
With 944 offset 16x7, or 16x8, less rubbing issues with 225's.
16x7s and 16x9s should look nice. Aftermarket wheels can provide more width and diameter.
Sherwood
Fishcop 05-04-2003 09:41 PM
Thanks Sherwood. Could you post a picture of your car again at some time?
Cheers
911pcars 05-05-2003 12:30 AM
There's some on the my rennlist website. The latest version is on the right.
But there's plenty of better examples of other guys' cars.
IROC 05-05-2003 04:28 AM
Re: 9" Fuchs on SC flared '69 Question
Cheers
Here's a pic of 9x17s with 275/40-17s on the rear of my car. They fit fine....
http://forums.pelicanparts.com/uploads/275-40-17.jpg
Mike
arrivederci 05-05-2003 05:17 AM
I posted something about this a while ago...with some pics of my turbo 7" wheel on the front of my '72. The clearance was tight. I'm not sure it will fit. See the thread below:
http://forums.pelicanparts.com/porsche-911-technical-forum/87120-16-inch-wheels-early-911-a.html
slammed1000 05-05-2003 05:29 AM
i have 18x10s and 18x8's on a 73 with rs flares with no problems. i wouldnt think that 9's and 7's would be a issue. everyone seems to be scared with this and if you do your homework you will find that you can get a much larger wheel with the correct offset or spacers with no lip rolling.
Mukilteo911 05-05-2003 09:50 PM
Fishcop, what happens when you chrome the fuches ?
