-   -   Suspension rebuild - how long/miles to "settle" before final alignment/cornerweight (http://forums.pelicanparts.com/porsche-911-technical-forum/1093775-suspension-rebuild-how-long-miles-settle-before-final-alignment-cornerweight.html)
chrismorse 05-18-2021 03:00 PM
I have seen many references to new/refreshed suspension "settling".
New bilstein HDs, 21-27 bars, HD rubber bushings, F/R.
How long does it take???miles/days???
How much will a suspension settle??
Will it do so evenly, or will things settle differently?
I plan to do a rough alignment, (string), then set heights/weights. If i had a rough average, or expected settlement, i could plan for it. If it is small, i might not need to do a realignment/cornerweighting.
I've only done this once before to a non porsche, so this is a whole new ball game.
Thanks,chris
brianlay 05-18-2021 03:34 PM
I think a few miles and most of the settling will be done
stownsen914 05-18-2021 06:34 PM
I always thought a trip down the driveway was enough. Will be curious to know if more than that is needed.
ian c2 05-18-2021 06:56 PM
Enough to compress everything a few times , so I trip to the local “rough” cobble road , or through the housing estates with speed bumps was what I was taught .
Back to check after that , then final check after 500 miles so was allways timed to do tyres or mot 500 miles after alignment .
Alan L 05-19-2021 12:57 AM
Around the block basically.
Alan
chrismorse 05-19-2021 07:24 AM
Thanks Guys,
Ill rough in the alignment, then give it a short run before the corner weight and alignment.
chris
