Alternative to metal grease cap for front struts?
Hi Peeps. anyone know easier to use/remove caps on the spindle ends for the front of 70s-80s 911? Plastic or rubber ? Mine are way hard to ooch off with a big set of pliers , and i am ending up changing rotors and hubs quite often for vintage vs other racing. PIA. thanks. Frank
Old 05-19-2021, 11:55 AM
porsher
aston@ultrasw.c's Avatar
I drilled and welded an M8 nut to the cap, it's easy to run a bolt and push the cap off.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 05-19-2021, 12:17 PM
fantastic idea aston. thank you!
Old 05-19-2021, 02:01 PM
Another idea is to use a metal table leg rubber.
Old 05-19-2021, 02:54 PM
It's a 914 ...
stownsen914's Avatar
Frank - I find it's a lot easier to remove those caps with a brass drift, tapping gently with a hammer. Place the drift vertically top tilted slightly toward the center of the car. Just enough angle to knock the caps outboard. Give it a knock, rotate the hub, another knock, etc.
Old 05-19-2021, 06:29 PM
Use 930 caps ?
This pic is off an 85 set-up I own .
Old 05-19-2021, 07:09 PM
porsher
not original, i borrowed it
also you can thread in a cap screw, put it in your drill press and clean up the OD with some emery cloth
79 928 Race Car
Old 05-19-2021, 07:37 PM
I misread it. I thought we talking the end cap on a Front Control Arm.
Old 05-19-2021, 08:33 PM
Alan L's Avatar
Do you have a press?
I just pressed mine off real easy a few days ago.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 05-19-2021, 11:40 PM
Mahler9th's Avatar
"I find it's a lot easier to remove those caps with a brass drift, tapping gently with a hammer. Place the drift vertically top tilted slightly toward the center of the car. Just enough angle to knock the caps outboard. Give it a knock, rotate the hub, another knock, etc. "
+1
I don't use a brass drift, I use a cold chisel. I few taps with a small hammer.
I have been using this method for 25+ years with zero issues.
I also suggest having a spare cap or two for track/race cars. I have only lost one cap in the past few decades, but I have given several caps to friends that were otherwise SOL.
They are small and don't take up much room.
I used to buy my spares from Partsheaven... they are now closed. But there are likely a few dismantlers around that have caps.
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 05-20-2021, 09:52 AM
Shaun @ Tru6's Avatar
Frank, I use a muffler clamp locked on the grease cap and the you can pry against the clamp. Here's a pic I found here, use a piece of wood between the prybar and the wheel hub.
Tru6 Restoration & Design
Old 05-20-2021, 10:40 AM
analogmike's Avatar
I've always just pried with a big screwdriver against the alum hub, there is usually a space between the cap and hub on my early 70's 911s.
Regards, Mike. AnalogMike at aol dot com
'73 911RS Clone, '08 911 GT3 cup,'04 Touareg, '16 Audi S3, '01 Viper GTS,'05 Bentley CGT, '50 Crosley Hot shot
my racing pages - http://www.analogman.com/911
~^v^~ aNaLoG.MaN ~^v^~ guitar effects LLC www.analogman.com
Old 05-20-2021, 12:01 PM
The muffler clamp trick is the only thing that worked for me on my '88. You really need that extra metal to have something to pry against.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 05-21-2021, 07:06 AM
sjanes's Avatar
I use these Vise-Grips to shimmy the cap off. Works really well.
87 Targa. It's completely stock. honest.
Old 05-21-2021, 07:49 AM
