Hello there,
Decided I definitely want 911R taillights for my 3.2 Carrera. Went browsing for 911R taillights housings and lens ... well, quite a hefty bill. So I went the DIY way. First thing first - the lights - I bought : 2 HELLA 2SA 001 259-751 for the Running/Stop lights (Red) 2 HELLA 2BE 001 259-061 for the Signal/Backup lights (Amber/White) The amber/white lights came with 2 bulb sockets - enough for the signal and backup lights. Problem was the red lights came with only one bulb socket and I do need 2 - one for the running light and one for the stop light. I then disassembled my car taillight and found out that stop and backup functions were assumed by a single dual filament bulb (12V P21/5W). Here is the problem : how do I fit this bulb to accommodate my 911R red light? ![]() Went online and bought a socket for the P21/5W bulb ![]() Now I need to design a part that would fit my new socket and the red lens. Hopefully I have this Prusa 3D printer to do this. All it takes is a couple of hours on Sketchup - multiply that by at least 2... ![]() The new part printed in PETG filament : ![]() Now all together - Et voilà! : ![]() ![]() ![]() Part 2 is going to be a full design of the 911R taillight housing with Sketchup to be 3D printed - in a couple of month (multiply that by at least 2...) |
light housing
Nice work. Did you ever save the printing program for this housing. This design is superior to all others I have seen. Did you make spares in case this breaks?
RETIRED
I'm in...
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Hi
Do the 911R style rear lights fit in place of the original wrap-around lens or does the whole rear light assembly/housing need to be removed? Thanks |
It never ceases to amaze me the resources we have today that we didn't have 10 years ago. Great job.
Definitely want to get a set from you or maybe it’s time I got a 3D printer.
Any thoughts on a design for a two bulb base for a red amber or clear amber lens? Brad |
I would rather be driving
Nicely done!
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
The red/amber or clear/amber lights come with a two bulbs base - the kind of bulb used for the interior light - should be enough for backup and signal
Carmagic.us
Did you make any progress on the lights.
How will you mount them ? Just buy the fiberglass insert and mount the 2 Hella lights on it ? Cheers Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems |
Under the radar
Following this. Can you share your file for the base? I have a CAD file shared here at Shift Fork Jig for 915s FREE It's on google drive.
Thanks for your effort. Looking forward to your part 2.
