First 911 Project Help
Just got my first 911 a few weeks ago that I found locally. After wanting one of these for most of my life the time has arrived and I have enjoyed tearing into this one. This a 1986 3.2 which I thought that I would never be able to afford. This one has been sitting outside for many years. As I am going though it I found this hanging wire under the car that I cannot figure out what it is or where it goes? Sort of goes up behind the transmission case.
Yes the car runs but not very good. Thanks for the help Brian http://forums.pelicanparts.com/uploa...1621621122.jpg http://forums.pelicanparts.com/uploa...1621621122.jpg http://forums.pelicanparts.com/uploa...1621621122.jpg |
your exhaust doesn't look like this but the rusty things above the axles control cabin heat http://forums.pelicanparts.com/uploa...1621627504.JPG |
That looks like the reverse light connector , two pins and a rubber boot?
Ian |
What sort of problems are you finding with engine? Any history as to why it was parked?
Best of luck as the Porsche adventure begins! |
That is how i got mine! Get a bentley book and start collecting parts for deferred maintenance. Plugs, wires, cap ,rotor valve cover gaskets oil filters fuel filter brakes you will be busy for a few months. Once you get it running good then drive it like you stole it. Congratulations!!
Hi Brian,
Welcome to the the brotherhood :-) A non running car could have a "few" difficulties. I'd recommend you do a PPI (Post Purchase inspection), If you cannot find a knowledgeable local brother to help you give the car a thorough look over, it might be "wise" to flatbed it to a trusted local mechanic to thoroughly asses the cars condition and needs. He/She should be able to help you prioritize the cars needs and give you cost estimates for getting it into shape. This forum has a huge amount of very knowledgeable owners willing to discuss your concerns and offer advice. It has been a huge help to me. Welcome , chris |
I hope this helps Ianhttp://forums.pelicanparts.com/uploa...1621693782.jpg http://forums.pelicanparts.com/uploa...1621693886.jpg |
Yes that is it!! Thank you!! Brian |
| All times are GMT -8. The time now is 04:51 PM. |
