Warren Hall Student
Bobboloo's Avatar
Getty Design R-type amber engine shroud
I was asked on a recent thread about the Getty Design engine shroud if I would post a picture after I finished assembly of the shroud so here goes.
Fitting this shroud was a lot more work than I would have imagined. The fit was not anywhere near the quality factory ones. It had to be really coaxed into place. It took me at least 12-hours to fit it. Measure, mark, cut grind, drill, test fit, mark, cut grind, drill, test fit, mark, cut grind, drill, test fit.
I must mounted and unmounted it at least 20 times.
The shroud comes in seperate pieces and has to be drilled and riveted together. It is rough cut so some additional trimming is necessary. All the holes for mounting need to be drilled.
Anyway the shroud looks pretty darn good though once it's finished.
The motor is a completely rebuilt 2.7RS replica motor but with carbs instead of MFI. More on it here.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 11-18-2008, 08:20 AM
Banned
gassy's Avatar
Send a message via ICQ to gassy Send a message via AIM to gassy Send a message via Yahoo to gassy Send a message via Skype™ to gassy
Really nice work
Old 11-18-2008, 08:31 AM
Thank you for validating what we tell out clients that consider aftermarket shrouds. It takes a ton of time to get it right! The more popular the maker for the part usually means the more time it takes to install.
Why? the same molds are used again and again. Each time a part is to be removed from the mold, the edges are ground back to separate the parts. Even the best molds out there get deformed over time , even in small ways.
The glib response would be " Well. they should make new molds off virgin masters then !" Sure and then the parts would cost 3-4 times more than they do now as they amortize the expense per part
Nice job Bobby- your distributor will be here later this week
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 11-18-2008, 08:39 AM
Warren Hall Student
Bobboloo's Avatar
Thanks Dave.
Fitting this shroud sure cured me of ever wanting to do it again.
Bobby
Old 11-18-2008, 08:55 AM
I would rather be driving
jpnovak's Avatar
The new engine looks great.
Bobby hit the nail on the head. Everything fiberglass takes lots of time to fit properly. I was going to install an amber shroud on my recent 3.2SS build. Then I decided that I didn't want to take the time and refinished the factory shroud. Eventually I will go back and add one - or maybe not.
Old 11-18-2008, 09:29 AM
Paul Thomas's Avatar
Dave,
I would like to get a new shroud but I deffinately do not want to go through that. What do you suggest?
Also, would a 1970 shroud fit on a later 3+ liter motor? I have been working on making the engine bay look a little more period correct.
Paul
My ignition is retarded.
Old 11-18-2008, 09:30 AM
Shaun @ Tru6's Avatar
has anyone installed the Series900 amber shroud? his door reproductions were excellent.
Tru6 Restoration & Design
Old 11-18-2008, 09:51 AM
Bought a c/f shroud from Autobahn Extremist for $600, as I remember. Took me about 15 minutes to install after I got the carburetors off.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 11-18-2008, 11:01 AM
Max Crawford sells a very accurate R / 906/ RSR engine shroud "kit" in oe style german glass for $1500..... and then you get to source the floating nutsert plates, drill all the holes and do final fit. The parts will not work on a regular engine; you have to use the small diameter fan ring, no engine mount oil cooler as that is the way the race engines were.
$600 is a deal if its a drop on to a stock engine !
1970 911 Targa "ST"
Old 11-18-2008, 11:05 AM
gestalt1's Avatar
i bought the rennspeed one and it was too green colored to me so i eventually ebay'd it. i then found a guy in indiana who previously made them for gt racing. the guy was a pain to deal with and it took forever to get the parts. it was reasonably priced at about $400 for the shroud and all the tin but the parts were trimmed poorly and the tin was a little warped. i'll most likely use used factory parts in the future. does anyone remember a supplier who mostly made 914 fiberglass that had a shroud that had the block-offs and extra cooling tunnels all as one part?
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 11-18-2008, 11:14 AM
Ferdinand Magazine
johndglynn's Avatar
Looks great Bobby, I am in for one of these next year some time.
Sheriff at www.impactbumpers.com
Brand support at classicretrofit.com/tuthillporsche.com
1976 Porsche 911 Carrera 3.0: 'The Orange' - 1981 924 Turbo - 1983 944 Lux - Too many BMW motorcycles
Old 11-18-2008, 02:50 PM
Warren Hall Student
Bobboloo's Avatar
I've heard very good things about Damon's shrouds but I know he only does a run once in a while. I think his main business is restoration, welding and collision repair. So he only does a run of fiberglass parts when time is willing.
Bobby
Old 11-18-2008, 05:07 PM
Warren Hall Student
Bobboloo's Avatar
Thanks. Feel free to PM me if you have any questions when the time comes although once you have the piece in hand and you start to fit it it becomes pretty obvious what needs to be done.
Bobby
Old 11-18-2008, 05:09 PM
78 in a '71
mossguy's Avatar
I still have my original black shroud, that is not so black anymore. Can it be refinished/painted? If so, with what, specifically?
Thank you in advance!
Best,
Tom
On glide path......
1971 911 T Targa
2013 Ford Fusion Titanium AWD
Old 11-18-2008, 05:10 PM
Zeke's Avatar
Best,
Tom
Painting FG is no problem if you can get it clean.
Bobby, looks way cool. The whole thing is way cool!
Old 11-18-2008, 05:14 PM
78 in a '71
mossguy's Avatar
Thanks Milt!
Best,
Tom
On glide path......
1971 911 T Targa
Old 11-18-2008, 05:22 PM
David's Avatar
It's purchases like that which make it the Gold Plated Porsche
FYI, I didn't realize there was as much of a method to the shroud color madness, but Panorama did a decent job of putting together a shroud color chart in this month's issue.
Old 11-18-2008, 05:29 PM
Sports Purpose 911 Driver
mjshira's Avatar
this is very impressive work, NICE! the attention to detail is what this hobby is all about.
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 11-18-2008, 06:05 PM
Those are the ONLY ones I will use any longer.
After fooling around for years with ones with fitment that ranges from abysmal to marginal and have the wrong color, its not worth it to me to use anything else.
We buy a lot of these from him for a variety of engines and customer projects.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-18-2008, 10:11 PM
I have one of Damon's amber fan shrouds on my engine - only required very minor tweeking for a perfect fit ...
Andy
M&W 904 ... now gone
GT-style 356C ... also gone
Old 11-19-2008, 12:44 PM
