'73 911 T Targa
Preventing nuts from coming loose
Which do you think does the best job of keeping nuts from loosening?
Nylon Insert nut; Split Lock Washer; Wavy Washer Outside Star Lockwasher Inside Star Lockwasher Regular nut with Locktite? |
In some ways it depends upon the application ie where it is to be used? There are also other versions of your list above.
I recently had a nylon insert nut
work it's way off the bolt. ? are these one time use only ? I need a foolproof method.
_______________________________________________ 45 yr addiction 1965 356 Coupe, '70 914- POS, '74 911- lightweightFUN, '83 SC Cab- 100%AnalogOpenTop. |
Junkers test is the vibration test used to compare various locking methods. In heavy rail, we use Nord-Locks almost exclusively.
https://www.youtube.com/watch?v=IKwWu2w1gGk |
I agree that nord lock is very effective. At Chrysler we allow nylon lock nuts to be reused 5 times and mechanical lock nuts to be reused three times (don't ask how we keep track)
Navin Johnson
Split washers are pretty much garbage
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Lotsa Locktite choices, incl. purple & green
Lock time works very well
Tighten the nut then damage the threads. It may loosen but not fall off.
Alternatively, after tightening, put a weld on it |
'73 911 T Targa
You didn't describe your fastener application. Is it a CV joint or a valve cover? A seat belt bolt or a nut that holds your radio in position? Is it a con rod nut or a muffler nut?
If it's a typical Nylok type nut and washer to hold engine covers on, I'd consider sourcing them from another supplier. If you can't describe the application, go to a factory repair manual and look up what's specified. S |
I just use Blue 242 Loctite. Simple and effective for my needs.
Bruce '12 Carrera S DFI '84 911 Carrera |
Just keep them in your pants!
Safety wire.
Thread locker. Not suggested, does not work in every application.
Safety wire. Not suggested, does not work in every application. Suggesting these as an overall threaded fastener answer is inaccurate, over-reaching and borderline OCD (as if OCD is a solution). Techies probably understand. Newbies might take those words as gospel. S |
Weld it. That'll work in every application
(LOL)
'80 SC Targa Avondale, Chicago, IL |
I studied Nord-Lock's web site content, and I plan to replace the washers on my '72E's suspension and drivetrain with these.
In some critical applications (e.g., eng & tranny brackets, trailing-arm-to-spring plate attachment, etc.) Porsche used specially-designed washers with ribbed sides (somewhat similar concept to Nord-Lock, except in one piece.) These (still available) may be a cheaper alternative to Nord-Lock. |
Thanks for the video to Nord Lock.
I'm convinced.
i`m surprised nobody has mentioned Schnorr washer look similar to Nord lock washer.Porsche has used these on several places on your 911
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
