Roy M's Avatar
CV joint replacement options
I've just noticed a split boot in my CV joint - no real sign of escaping grease so I think (hope) I caught it early. I need to replace the boot soon (like as soon as I get the parts!) but have 3 options available to me
Replace boot - cost approx £15 - approx $22
Replace joint - cost approx £33 - approx $48
Replace driveshaft - cost approx £160 - approx $230
Given that the car has done 102000 miles any thoughts on what I should do? - the cheapest obviously appeals and I don't want to replace parts unnecessarily but I also don't want to have to do a job twice in quick succession! I also need to wait for parts so if I get the joint off and it's bad I'm off the road for a week or so - not really a problem but a factor
One other thing that has just occurred to me - do I need 2 boot kits? if I'm doing an outer am I likely to rip the inner doing it? - is it cheap insurance?
Roy
Old 05-06-2003, 12:47 AM
zymurgist's Avatar
I just did the inner right boot. Left the outer one alone. I hope that doesn't come back to bite me in a few months...
Ken
1974 Porsche 914 2.0 "Babydoll"
Old 05-06-2003, 03:50 AM
IROC's Avatar
As a minimum, I would replace the split boot and remove, clean, inspect and repack the CV joint. These CV joints are amazing robust and unless it has been run for a long period of time without grease, you should be fine.
If you're really looking for a project, remove and clean/repack all of them. It's really not necessary, though.
No need to replace the driveshaft (or any of the CV joints themselves) unless there is really something wrong with them....
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 05-06-2003, 05:37 AM
TurboRuf's Avatar
Roy,
I'm in the process of replacing all four CV joints, boots, etc. after discovering a rip in one of my boots. Do a search on my user name to see what I uncovered after cleaning the joints. My case may be an exception but I was surprised at what I uncovered.
85 930 Ruf BTR
Old 05-06-2003, 06:08 AM
Roy M's Avatar
I did a good search andhave downloaded the instruction sheet put up by Early-S-Man so think I know what I'm doing. I think I'll get the boot kit and see what happens when I strip it down. I've seen your problems TurboRuf and just hope mine goes a bit easier than yours
Roy
Old 05-06-2003, 06:16 AM
The brand new CV shaft assembly is about the same price if you remove the CV joint, repack and replace the boots. My shop was going to repack and replace the boot. I just replaced a band new shaft instead. It sounds like a logical choice because labor is expensive.
Caliber
1987 911 Cabriolet
Old 05-06-2003, 10:11 AM
IROC's Avatar
Ahhhh...but if you do it yourself, it only costs about $50 for two new boots and some grease.
Our host Wayne sells new axles (complete with two new CV joints and boots) for $346 each for my car. That makes it a no-brainer for me.
Mike
Old 05-06-2003, 10:22 AM
mussberger's Avatar
I installed complete new halfshafts and found out that that was not my problem but it is quieter.
1981 911SC Black metallic, no sunroof. Sold(damnit)2005 987Guards Red, Stuttgart build. Sold1978 911SC Bahama Blue, M491 look E class PCA race car.Sold with help from Pelican. Thanks! 2005 997 Black. Sold1988 930 Grand Prix White. Keeper. 2008 957 Basalt Black, Pneumatic suspension and PDCC.
Old 05-06-2003, 04:39 PM
