Tensioner Upgrade
Can experts please chime in if my parts are correct for my 2.0 tensioner upgrade? I also have the tensioner rebuild kit but not shown. Thank you!
Old 05-22-2021, 10:10 PM
66 911 #302694
Arctic Rat's Avatar
Hi,
Not an expert by any means, but I think the tensioner you want is a 930 type. (Chain tensioner 930.105.501.0R) those are 901 early types.
Joe D
My life is not a journey to the grave, with the intent of arriving safely in a pretty, well preserved body, but rather I will skid in broadside, thoroughly used up, totally worn out, and loudly proclaim .....
WOW WHAT A RIDE!!!!!!! reaperwear
Old 05-23-2021, 03:13 AM
I was told this is the equivalent 901.105.519.0R of the 930.105.501.0R...experts please Thank you very much
Old 05-23-2021, 10:05 PM
Those are original tensioners with small reservoir not the equivalent of 930’s. They look the same but the 930’s have upgraded internals and reinforced housing.
Old 05-24-2021, 06:46 AM
Upgraded tensioner........
Targaboy,
Could you post pictures of the idler gears showing the top view? Maybe you meant the wider idler gears introduced in late SC motors? Thanks.
Tony
Old 05-24-2021, 03:29 PM
Thanks for your response Tony but do these part numbers help to answer your question regarding the idler arms? 901.105.545.03
Can someone please confirm if the tensioners I have are equivalent to the 930 tensioners as I was told by the original Seller? Cheers!
Old 05-31-2021, 12:55 AM
totle's Avatar
the 901. is the early ones. The one starting partnumber with 930, is the newer and upgraded version that is better.
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 05-31-2021, 01:23 AM
Is this a better shot of the idler arms?
Old 05-31-2021, 04:29 AM
I can't seem to find the 930.105.501.0R here on Pelican parts....Thanks for your response!
Old 05-31-2021, 04:35 AM
Wider bushing idler gears........
Targaboy,
The top 2 idlers gears are for cylinders 1-2-3 (lower one is the wide/upgrade).
The bottom 2 idlers are for cylinders 4-5-6 (lower one is the wide/upgrade).
Tony
Old 05-31-2021, 05:03 AM
Thanks Tony! Whew! At least I got the idlers right
Old 05-31-2021, 07:12 AM
