Tensioner Upgrade
Can experts please chime in if my parts are correct for my 2.0 tensioner upgrade? I also have the tensioner rebuild kit but not shown. Thank you!
66 911 #302694
Hi,
Not an expert by any means, but I think the tensioner you want is a 930 type. (Chain tensioner 930.105.501.0R) those are 901 early types. Joe D
My life is not a journey to the grave, with the intent of arriving safely in a pretty, well preserved body, but rather I will skid in broadside, thoroughly used up, totally worn out, and loudly proclaim ..... WOW WHAT A RIDE!!!!!!! reaperwear |
I was told this is the equivalent 901.105.519.0R of the 930.105.501.0R...experts please
Thank you very much
Those are original tensioners with small reservoir not the equivalent of 930’s. They look the same but the 930’s have upgraded internals and reinforced housing.
Upgraded tensioner........
Targaboy, Could you post pictures of the idler gears showing the top view? Maybe you meant the wider idler gears introduced in late SC motors? Thanks. Tony |
Thanks for your response Tony but do these part numbers help to answer your question regarding the idler arms? 901.105.545.03
Can someone please confirm if the tensioners I have are equivalent to the 930 tensioners as I was told by the original Seller? Cheers! |
Trond R. 1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc.. 1972 914-6 GT replica project 1986 944 Turbo |
Is this a better shot of the idler arms?
Wider bushing idler gears........
Thanks Tony! Whew! At least I got the idlers right
