Odd cutouts on Fuchs lug hole seats (PIC)
Hi - I had the wheels off my '83SC, and noticed some weird cutouts at a couple of the lug holes. Does anyone else have these? Can't imagine they were for balancing...
Someone drilled out a locking lugnut most likely.
Awesome. “If these wheels could talk…”
Thanks for the reply John! |
Red Line Service
You do realize that the integrity and safety of the wheel has been severely compromised by the fool that butchered that wheel!
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
this absolutely idiotic by somebody before you to remove broken lug nut.!!
As for a safety, you have most likely driven your 911 for a while like this. i`d suggest if you are using wheel lock-nut put it on this spot..also i would not use steel lug nuts as is it a fashion lately..use only alu lug nuts You will be fine ,you still have 4 other (did not see it) lug nut mounting without damage...i have seen worth... Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
