79 911. stripped injector port
does anyone have a good fix for rethreading without getting shreds into engine? it's # 6 cy. thx
Old 06-02-2021, 06:17 AM
I would rather be driving
jpnovak's Avatar
Not sure what you're referring to...
The CIS injector ports are not threaded. They are pressed in.
Old 06-02-2021, 06:30 AM
Registered Minimalist
75 911s's Avatar
They will spin in the injector sleeves. Or are you referring to the fuel lines nut / injector where it threads to the injector?
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 06-02-2021, 07:10 AM
CIS Injector sleeve........
gdj,
Maybe you meant “injector sleeve”. Best way to replace old and brittle injector sleeve is to remove the intake runner from the motor and do it on the work bench. Some of these are easy to remove but others could break and crumble down to the cylinder head.
Tony
Old 06-02-2021, 08:52 AM
79 911
thx guys... i had incorrect info from mech. problem solved.
Old 06-02-2021, 04:37 PM
