Rear light assy wiring bundle 911SC
Rear light wire bundle / 1980 911SC
I want to remove the wiring harness for the pax side rear light assembly.
Any insight as to the technique / process to elegantly accomplish the task [where you don’t bugger up the part].. Push from inside engine compartment?
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 05-27-2021, 12:41 PM
If you want to get it out of the light assembly, you will need to remove the light assembly from the car then remove the plate off the light assembly and disconnect the associated wither from inside the light assembly. with the wires disconnected you can then remove the grommet and wires from the plate.
Old 05-27-2021, 01:28 PM
ROW '78 911 Targa
timmy2's Avatar
To get the 6 pin connector out of the body.
Push the outer edge of the 6 pin female connector towards the center of the connector and out towards the light fixture.
I use a wide, dull flat blade screwdriver.
Once you get some started the rest will follow.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-27-2021, 05:23 PM
Dennis:
Got it... pushed the outermost portion of the gasket towards the center- while also pushing the center of the plug through the hole - came out very cleanly..
kgl
Kim Langley
80 911SC
97 C230
73 BMW 2002Tii
Old 05-29-2021, 07:04 AM
ROW '78 911 Targa
timmy2's Avatar
Good.
The hard part is getting it back in...
Dish soap with a little water is your friend.
Dennis
Old 05-29-2021, 07:14 AM
Dennis :
thanks - I'll make a note of that technique
kgl
Kim Langley
80 911SC
97 C230
73 BMW 2002Tii
Old 05-29-2021, 05:37 PM
Harpo's Avatar
Originally Posted by timmy2 View Post
Good.
Reinstallation is a PITA.
Old 05-30-2021, 04:06 AM
Harpo: I think that "Porsche Law of the Universe" goes without saying...
Lube the sucker up - have a cold one handy.... some good tunes blasting... "clear the mechanism".... and get on with it.... // multitude of various prise tools handy...
It's the cost of our passion... - I'll deal with it....
kgl
Kim Langley
80 911SC
97 C230
73 BMW 2002Tii
Old 05-30-2021, 03:00 PM
ROW '78 911 Targa
timmy2's Avatar
Update after installing a new dash harness in my car today with 6 of the female connectors.
The soapy water will work eventually, but I decided to use some Dow Corning 111 lube, and they popped right in easy peasy with a firm straight push.
Dennis
Old 06-02-2021, 11:36 PM
Dennis:
thanks for the tip >> just ordered some off Amazon... sometimes - when you have the correct tools for the job >> things work "more-better"...
Kim Langley
80 911SC
97 C230
73 BMW 2002Tii
Old 06-03-2021, 06:12 AM
