-   -   Cost To Fix Broken Head Studs? (Studs Only No Rebuild) (http://forums.pelicanparts.com/porsche-911-technical-forum/1094804-cost-fix-broken-head-studs-studs-only-no-rebuild.html)
Kat911 06-01-2021 12:19 PM
I was in the process of replacing my old heat exchangers with SSI's and came across a couple broken head studs. I'm wondering what I should expect cost-wise if I take it in to my local Porsche garage (not dealership) and have them remove the broken studs. I am not in the market for a rebuild at this time. That will take too long and I want the car back soon to use for the summer (maybe a rebuild over the winter). I don't have the time, tools, etc. to get in there and do it myself, so any expectation on what people think is an appropriate cost just to get the studs taken care of right now is appreciated.
yelcab1 06-01-2021 12:27 PM
40 hours times whatever hourly rate you want. And cost of studs ($500), plus gaskets, and lubrication. So, $1000 for parts and 40 hours. You might be able to cheat and remove the heads, cams, and tower all in one shot. That would save some money.
theiceman 06-01-2021 12:32 PM
heads and cylinders have to come off so... there is your rebuild.
if you only have one stud off for each set of 4 i would leave it , drive it for the summer and have them repaired over the winter and have any valve/ ring work done at that time. You have to tear the whole top down to do studs and that is the time to do valves/rings.
cabmandone 06-01-2021 12:36 PM
If the head studs aren't on the same cylinder just drive it and get it fixed in the fall/winter.
john walker's workshop 06-01-2021 02:54 PM
What engine would help. Info is everything. I do a whole valve grind for 40 hours labor on most of them, including lower steel studs, so quotes will vary.
proporsche 06-01-2021 03:07 PM
more info needed as John said what year?...the studs i would use steel not expensive at all
$330 bucks from our host............plus upper gasket set https://www.pelicanparts.com/More_Info/PELREBKT03N.htm?pn=PEL-REBKT-03N&bt=Y&fs=0&SVSVSI=911M
Bill Douglas 06-02-2021 02:13 AM
It would be a shame to pull it to bits without doing a few things like John said, a valve grind and maybe new valve seals.
cabmandone 06-02-2021 03:56 AM
There's a lot of info missing from the OP to say that they should do a valve grind and valve stem seals. I took my engine apart due to broken head studs, inspected everything, found it to be in good shape, put new head studs in and put the engine back together.
"While I'm in there" will eat up that green stuff in your wallet fast and many here are more than anxious to help folks spend their money. Evaluate based on mileage and condition and go forward from there. What I'm sayin is, if it ain't broke don't fix it.
gomezoneill 06-02-2021 05:40 AM
I'll buy the car from you!
Rodsrsr 06-02-2021 11:36 AM
Are you sure you're talking about head studs and not exhaust studs? You typically discover broken head studs when removing the valve covers and I'm not sure why you'd be pulling the valve covers to install SSi's.
michael lang 06-12-2021 01:10 AM
I was thinking the exact same thing. I know that the OP stated that he didn’t have time to do it himself but if the issue really is just a broken exhaust stud I would think spending just a couple of hours and a few hundred dollars in parts and a stud removal tool should do the trick. Kat911, would it be possible for you to clarify many maybe even post a pic of what you’re working on so the group can help give you the best path to follow in fixing your car?
GaryR 06-12-2021 05:15 AM
Gotta love people that come here (post #1), ask a question, and here it is 12 Days later and they don't bother looking at the answers...
tdskip 06-12-2021 05:22 AM
Which engine? If a 2.7L it often times is a very slippery slope.
GaryR 06-12-2021 05:52 AM
Yep, except I believe the OP is talking about an exhaust stud, NOT a head stud.. but he would have to actually participate in his own thread to find out!
theiceman 06-21-2021 11:06 AM
.....and ....gone !!!!
