Cost To Fix Broken Head Studs? (Studs Only No Rebuild)
I was in the process of replacing my old heat exchangers with SSI's and came across a couple broken head studs. I'm wondering what I should expect cost-wise if I take it in to my local Porsche garage (not dealership) and have them remove the broken studs. I am not in the market for a rebuild at this time. That will take too long and I want the car back soon to use for the summer (maybe a rebuild over the winter). I don't have the time, tools, etc. to get in there and do it myself, so any expectation on what people think is an appropriate cost just to get the studs taken care of right now is appreciated.
40 hours times whatever hourly rate you want. And cost of studs ($500), plus gaskets, and lubrication. So, $1000 for parts and 40 hours. You might be able to cheat and remove the heads, cams, and tower all in one shot. That would save some money.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 Last edited by yelcab1; 06-01-2021 at 12:29 PM.. |
heads and cylinders have to come off so... there is your rebuild.
if you only have one stud off for each set of 4 i would leave it , drive it for the summer and have them repaired over the winter and have any valve/ ring work done at that time. You have to tear the whole top down to do studs and that is the time to do valves/rings.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Brew Master
If the head studs aren't on the same cylinder just drive it and get it fixed in the fall/winter.
Nick |
What engine would help. Info is everything. I do a whole valve grind for 40 hours labor on most of them, including lower steel studs, so quotes will vary.
more info needed as John said what year?...the studs i would use steel not expensive at all
$330 bucks from our host............plus upper gasket set https://www.pelicanparts.com/More_Info/PELREBKT03N.htm?pn=PEL-REBKT-03N&bt=Y&fs=0&SVSVSI=911M
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
It would be a shame to pull it to bits without doing a few things like John said, a valve grind and maybe new valve seals.
Brew Master
There's a lot of info missing from the OP to say that they should do a valve grind and valve stem seals. I took my engine apart due to broken head studs, inspected everything, found it to be in good shape, put new head studs in and put the engine back together.
"While I'm in there" will eat up that green stuff in your wallet fast and many here are more than anxious to help folks spend their money. Evaluate based on mileage and condition and go forward from there. What I'm sayin is, if it ain't broke don't fix it.
Nick |
I'll buy the car from you!
Grappler
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
I was thinking the exact same thing. I know that the OP stated that he didn’t have time to do it himself but if the issue really is just a broken exhaust stud I would think spending just a couple of hours and a few hundred dollars in parts and a stud removal tool should do the trick. Kat911, would it be possible for you to clarify many maybe even post a pic of what you’re working on so the group can help give you the best path to follow in fixing your car?
Mike '89 CARRERA #402 |
Gotta love people that come here (post #1), ask a question, and here it is 12 Days later and they don't bother looking at the answers...
Gary R. |
Which engine? If a 2.7L it often times is a very slippery slope.
1967 912 (now w/ 50% fewer random holes in it) 911 w/ 3.2 1974 914 (3.2L swap underway) 1984 928s (S4 engine and suspension), 1987 928S4 |
Yep, except I believe the OP is talking about an exhaust stud, NOT a head stud.. but he would have to actually participate in his own thread to find out!
Gary R. |
.....and ....gone !!!!
