G-Series 15 inch wheel options
Looking for suggestions on aftermarket 15 inch wheels, ideally 8" front & 9" rear. Car is an 86 Carrera and Fuchs doesn't offer the offsets I believe that I need.
Background For the track I run 8 & 9X16 Fuchs with 225/245 tires. With negative camber and rolled fender lips I've made them work in the front but it is tight. Plenty of grip for a 2550lb/230hp car but on most tracks I never need 5th gear! For autocross I run 7 & 8X15 with 225 Hoosier A7 tires all around. Makes the car a little loose but the balance is good for autocross and much quicker, especially out of low speed corners. Also, I can rotate tires front to rear as they wear out. I've tried the autocross wheels/tires on the track a couple of times and the car is quicker but I miss the higher grip of the 245 rears and the tires can quickly overheat (they're A7s). So my goal is to find some wheels that allow 225/245(or maybe more?) on 15 inch wheels. I've always preferred Fuchs for the strength and low weight but the available offsets won't work. Any suggestions? Thanks Brian |
9x15 Fuchs.. or minilite replicas.
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
Braid does, probably some other custom wheels makers too in front you want 8ET27, but ET25 to 30 work but are just are a bit more compromised one way or the other, tire would probably be 225/45 in back 9ET15 is a great fit but down to ET11 or so also works depending on the tire and suspension setup, ideally, for a performance application, 9.5ET19 would be used(very little wiggle room here) tire 245/40
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 05-28-2021 at 11:47 AM.. |
You don't ay what tires you are using but here's a comparison of 2 relevant 100tw track oriented tires left is 16 right is 15, besides increased grip you gain over 27lb-ft in the acceleration dept. w/ the 15s, wheels weights for the 15s are estimates based on the same widths in 17s
Currently have Hoosier R7 225/50-16 and 245/45-16 on 8&9 Fuchs for the track. Have also used Toyo RR in the past in the same sizes, not as much grip but last a lot longer!
I was thinking I would use 225/50-15 and 245/40-15 Hohos on 8 & 9 15 inch wheels Remember one of my goals is to drop the gearing by going to 15s the 245/40 really wants a 9 inch wheel, I guess the 225/50-15 could use a 7 but would be happier on an 8 my current autocross A7 fronts are 225/50 on 7 and they seem a little pinched. 7X15 Fuchs are widely available. Is going to an special order 8X15 on the front going to be worth it? |
HoHO to HoHo the torque gain is even more dramatic, ~42lb-ft
yes the 16 115/45 & 245/40 want 8 & 9 the 15 s 225/45 & 240/40 want 8 & 9.5, though yes you could use7&9 or 8 & 9
Thanks Bill!
You've validated what I suspected. |
Did you see these??
https://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1094144-2-bbs-15x9-wheels-fs.html
Thanks Byron I had not seen that.
