Odd cutouts on Fuchs lug hole seats (PIC)
Hi - I had the wheels off my '83SC, and noticed some weird cutouts at a couple of the lug holes. Does anyone else have these? Can't imagine they were for balancing...
Old 06-03-2021, 06:39 AM
Someone drilled out a locking lugnut most likely.
206 637 4071
Old 06-03-2021, 06:44 AM
Awesome. “If these wheels could talk…”
Thanks for the reply John!
Old 06-03-2021, 06:54 AM
Red Line Service
Marc Bixen's Avatar
You do realize that the integrity and safety of the wheel has been severely compromised by the fool that butchered that wheel!
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 06-03-2021, 07:32 AM
proporsche's Avatar
this absolutely idiotic by somebody before you to remove broken lug nut.!!
As for a safety, you have most likely driven your 911 for a while like this.
i`d suggest if you are using wheel lock-nut put it on this spot..also i would not use steel lug nuts as is it a fashion lately..use only alu lug nuts
You will be fine ,you still have 4 other (did not see it) lug nut mounting without damage...i have seen worth...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 06-03-2021, 02:17 PM
