JWest Rennshift Shifter
Hello,
I purchased a new Rennshift and I want to retain the heater control lever. There is no provision for it in the base of the shifter. Any suggestions besides milling a slot to accept the lever? I called and emailed JWest, but they haven't replied, or called back. Apparently, this is their SOP. |
Hi, the heater controls are on your handbrake assembly, no need to modify anything.
Best, Tom http://forums.pelicanparts.com/uploa...1622911077.jpg |
What year is your 912. 74-87 should mostly be the same 915 style tower which the jwest replaces entirely. As mentioned the heater lever is back by the hand brake.
65-67 912 (don’t know about same year 911’s) have the heater lever directly in front of the shifter. I would cut a slot since the shifter is such a marked improvement over stock. The Rennshift fits either 901 or 915 transmissions. Just have to turn them around somehow.
| All times are GMT -8. The time now is 12:48 PM. |
