JWest Rennshift Shifter
Hello,
I purchased a new Rennshift and I want to retain the heater control lever. There is no provision for it in the base of the shifter. Any suggestions besides milling a slot to accept the lever? I called and emailed JWest, but they haven't replied, or called back. Apparently, this is their SOP. |
Hi, the heater controls are on your handbrake assembly, no need to modify anything.
Best, Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
Registered Minimalist
What year is your 912. 74-87 should mostly be the same 915 style tower which the jwest replaces entirely. As mentioned the heater lever is back by the hand brake.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
65-67 912 (don’t know about same year 911’s) have the heater lever directly in front of the shifter. I would cut a slot since the shifter is such a marked improvement over stock. The Rennshift fits either 901 or 915 transmissions. Just have to turn them around somehow.
Tony 1973 914 2.2 FAT Black 1974 911 Targa Lime Green 2018 Macan GTS White 2019 Targa GTS Agate Grey |
