bcgreen's Avatar
Adj. idle on 2.7 mfi engine
Will I need to stop the car each time I want to make an adj. to the idle mixture screw?
66 Shelby Hertz Renta-Racer
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 06-11-2021, 08:48 AM
Registered Minimalist
75 911s's Avatar
Yes. If I understand you correctly, your problem is that idle is moving all over the place. Something else is wrong. You need an MFI guru to look at it. The RPM transducer relay compensates by reducing fuel when RPM is below 1300. Is everything plugged in? Is this a hot rod or stock MFI setup?
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 06-11-2021, 08:55 AM
Yes.
206 637 4071
75 911s's Avatar
You could hire a little person to sit back there, but they might get really hot. And the fumes can make them angry.
Old 06-11-2021, 08:56 AM
BURN-BROS's Avatar
lol
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 06-11-2021, 09:01 AM
bcgreen's Avatar
No, the idle is just a little low, it runs better if pull up just slightly on the handle throttle.
Total stock. I could just leave it alone but I just want to get it a bit better
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 06-11-2021, 09:21 AM
75 911s's Avatar
In that case I would just ever so slightly adjust the idle screws on the TBs. Then Drive it. I'm talking like less than a 1/4 turn at a time. Mark your start position or you will go down a rabbit hole of black art MFI tuning.
Drive it first to get it to temp, then do a slight adjustment to all 6 screws, drop the hand throttle to the floor and see where that puts you.
Old 06-11-2021, 09:30 AM
bcgreen's Avatar
Going to take pics.
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 06-11-2021, 09:44 AM
Mixture is at the pump. Speed is the air screws on the stacks. They are adjustable with the engine running, the mixture adjust w/not running. Mixture adjustment can also change the idle speed. So, 6 of one, 1/2 dozen of the other.
206 637 4071
Old 06-11-2021, 09:52 AM
BURN-BROS's Avatar
These cars are old, I don’t think I would make any adjustments until I removed the mfi thermostat and ran an adjustable plate there to verify I am making adjustments on a fully “warmed” up injection pump. The thermostat thermal washers likely have wear and there is a decent chance the thermostat never goes to the full lean position. Also, all adjustments need to be done on an engine that is up to operating temp. Air flow should be between 4-5kg/hr at idle.
Burnham Performance
Old 06-11-2021, 05:13 PM
tobluforu's Avatar
If your idle is low and that is all that is wrong, buy this: https://www.amazon.com/Latest-Rage-5385730856-Carburetor-Airflow/dp/B00CMC57R0/ref=asc_df_B00CMC57R0/?tag=hyprod-20&linkCode=df0&hvadid=309898128610&hvpos=&hvnetw=g&hvrand=17170621531131431622&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9021760&hvtargid=pla-568420224882&psc=1
Also get yourself a really long screwdriver, one that is 2 ft., give or take. Get your car nice and warm, pull over, pull air cleaner, stick the device above in each stack, find the one that is receiving the most air, adjust the others to match. If that isn't enough after you drive it more, then turn them out a little at a time. This might take a few times to get right.
Good luck.
Old 06-12-2021, 10:41 AM
bcgreen's Avatar
I have one of these that I useto use on the webers on my TR6
https://www.amazon.com/Edelbrock-4025-CARB-SYNCHRONIZER/dp/B00062YC2E
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 06-12-2021, 01:42 PM
I like the Uni-Syn for the SU carbs on my Healey, but I think the Weber redline works better on the MFI stacks.
https://www.amazon.com/Redline-Carburetor-Synchronizer-Synchrometer-STE-SK/dp/B08MWRDZJC
There's a slippery slope thing here...I have to admit I couldn't get them perfect until I pulled the throttle bodies off the car and synchronized them using the shop-vac technique here:
Another MFI correlation attempt. . . LONG
Old 06-12-2021, 02:01 PM
bcgreen's Avatar
I don't want to get too carried away with this. It runs just fine as is so I will let the next owner deal with it.
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 06-12-2021, 03:48 PM
Check your timing and make sure your distributor is free and retarding correctly. These run a retard at idle rpm. Check full advance at higher RPM with no vacuums hoses and then check at idle with hoses connected.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 06-12-2021, 04:28 PM
bcgreen's Avatar
I did a tune up not long ago, everything spot on. Just need to fiddle with the idle sometime when I have nothing to do
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 06-12-2021, 05:05 PM
