WebCam 20/21 questions
Hey guys
I have some questions about WebCam 20/21 camshafts. First, do I really have to upgrade the valvetrain? I already have new OEMs. ![]() Do any of you have first-hand experience with them? maybe on an SC 3.0? what do they "do" for your engine? Are they bad for MPG? (or kml ... I'm from Europe) Maybe this is a "weird" question, but I have my reasons/ideas ...I was considering using 964s but have been offered a set of WebCam 20/21 at a good price. ![]() I really want to hear your stories- experiences! ![]() ![]() Here are my engine specs: 1979 engine block: boat tail web Crank: standard 70.4mm. Alu pressure plate. Standart lightened and polished connecting rods (-100g each) 95mm wössner, or JE pistons. 11.3: 1 compretion (as light as you can get them, so I'm leaning towards wössner) Exhaust: SSI. 2 in 2 out muffler. (the one I have is right through ... so I'll probably modify it slightly ... for the sake of my neighbors) dual ignition, MS3 box, knock sensor. Individual throttle body, and homemade intake manifold, their length is determined by final choice of cam, muffler, etc. Cheers, mads aka. Aircooled4evr Last edited by Aircooled4evr; 11-30-2019 at 08:54 AM.. |
Would you be using them with SSIs or similar?
Wish you the best on your engine build, Regards EDIT: Agree with Ted . . . we did send cams and rockers to WebCam for refresh/modify "should replace with new polished rockers when going to another new cam or used cam to allow work hardening process to repeat itself. "
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine Last edited by Sboxin; 11-30-2019 at 05:24 PM.. Reason: correction - added info |
The cam rockers are work hardened and worn in from the first camshaft and the bushings are worn too, should replace with new polished rockers when going to another new cam or used cam to allow work hardening process to repeat itself.
1980 911 - Metzger 3.6L 2016 Cayman S |
Fortunately, I was already going to do this myself, with a little help from my friends (not The Beetles) ![]() So I don't need stronger valve springs then? |
have any of you experienced with WebCam 20/21 and valve springs? Original or other?
Senior Member
I have those cams. Stock valve springs. I left the rockers alone. There is controversy about the wisdom of resurfacing those. I LOVE these cams. The dyno guy stared at my power band, saying it looks like a V8 graph. Shaped like a table. Good, smooth power all the way from 1500 rpm to redline. Very driveable. If you are looking to squish all the power into the highest RPM bands, this is not the cam for you. If you are looking for good torque throughout the RPM range, then you will like these cams.
Also, in the early sixties there was emphasis on the "beat" of the new pop music. A band incorporated that nomenclature into its name. BEATles. Not beetles.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Targa_PB_78_SC
I went with new OEM springs based on discussions with the gent doing my heads. Web cam stated stock valve springs are fine with the 20/21 cams.
So I’ve stock springs. All seems well with my first 400 miles on my rebuild Changed exhaust, pistons and cylinders to 3.2 with 9.5 CR ratio. The car feels hungry. Oh and I replaced all rockers which were not shiny smooth with ones which were.
BareRearedRookie Last edited by mike sampsel; 12-07-2019 at 12:44 PM.. |
okay okay ... Beatles! Superman vs. Aircooled4evr 1-0
Then I'll try too!
Also been using 20/21's with stock valve train for many years now with no problems. Road and track use.
1986 3.2 to 3.4 conversion |
ROW '78 911 Targa
Good read on springs here:
A Performance killer in these small power output engines.
Evil Genius
My 82 SC had Web 20/21's. SSI's and Monty single out muff.
Cams are very nice improvement over stock. Fully usable torque below 4K rpm and 5-7K is heaven. fast rev, no regrets. all stock valve springs. do it.
Life is a big ocean to swim in. Wag more, bark less.
Thanks for your input!
I have been confirmed in my idea to use WebCam 21/21 They are now on the table, waiting to be fitted together with the rest of the new engine parts!
I'm thinking about these for my basically stock 3.2 (cat bypass, modified OEM muffler). My question is whether the 20/21s require a custom chip/programming for the ECU. I have a Steve Wong chip now. Will this work?
'72 911 3.2 '18 Mustang Eco PP '17 Mustang GT Conv |
You might be able to get away with a hotter cam on motronic? These cams were designed for CIS from memory. They maxed out the overlap, had high lift and short duration. Setup so as not to wreak havoc with the airflow sensor on CIS. I have them in a stock 3.0L and they certainly eeked a little more out and would highly recommend them to anyone looking to do not much to a 3.0L
You should check with Steve Wong. When I rebuilt my engine several years ago I included the 20/21 cams (they are great, BTW), Steve re-did the chip for me (I went to 3.4, MM pistons, etc.). Not sure what he changed specifically because of the new cams, though, but I have to assume it mattered.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
