Slippery Slope Expert
Steam Driver's Avatar
Air Duct Hose
Is there a place to source air duct hose (between the fan housing and the heat exchangers) other than by P/N?
Doing that gets you a 380mm length, (1965-1989) which is about an inch too short to be easily installed. I’m thinking originality be damned, just get some aircraft high-temperature hose and be done with it!
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.”
Old 06-13-2021, 02:25 PM
midnight911's Avatar
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 06-13-2021, 03:46 PM
Call 911
dkirk's Avatar
Try Wicks Aircraft Supply - they stock all sizes and grades of silicone aircraft ducting.
https://www.wicksaircraft.com/shop/aeroduct-ducting/?searchTerm=aeroduct
Dave Kirk
My Porsche restoreth my soul.
Old 06-13-2021, 04:21 PM
Just ordered some from Aircraft Spruce. No shipping notice after a week so I called. Apparently the hose I ordered (the orange 2.5 inch) is in extremely short supply. They are giving me a ship date of mid October. And I only ordered 3 feet of it to go from SSIs to heater box.
Let us know if you are able to get it from Wicks.
Good luck.
Old 06-13-2021, 08:29 PM
You know that hose "accordions," right?
Source the OEM piece from our host.
Old 06-13-2021, 08:32 PM
Jeff Alton's Avatar
We buy the 2.5 inch in 12 foot lengths from a local hose/fitting/hydraulic supply house. It is a very good product.
Look locally at your local supply houses.
Cheers
www.turn3autosport.com
Old 06-13-2021, 08:43 PM
Don’t we want it to accordion? Flexible is good here.
If you mean 930-211-622-01-OEM or any of the ones listed as 60mm diameter they do not fit as the diameter of the hose and the heater box and SSI outlets are all 60mm. The hose will not slide onto either side without having to slit the end to make it larger.
Aircraft stuff is usually pretty well made. The 2 1/2 inch tubing (63.5mm) is just big enough around to fit well. Same color as the Porsche hose (orange). May not be OEM but looks almost the same. Seen many post here where others have used it successfully so I will give it a try.
Old 06-14-2021, 06:11 AM
Cheers
I live in a pretty small town. Not sure we have a hose/hydraulic supply house nearby but I will look around. Thanks for the suggestion.
Old 06-14-2021, 06:13 AM
Northern Motorhead
wildcat077's Avatar
Try a place like Summit Racing or HRP ... they carry Sceet ducting.A lot of people use that type of ducting for brake cooling as well.
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 06-14-2021, 06:17 AM
NickP's Avatar
I get air hoses from Newco. Proper back cloth with correct markings and pattern:
https://www.newcoproducts.com/
Nick
Euro Spec 73 911S
72T, now ST
R Gruppe, S Registry
Old 06-14-2021, 06:20 AM
gtc gtc is offline
abides.
gtc's Avatar
I got tired of the poor fit of SCEET duct, so I paged through the ventilation section of the PET catalogs and looked for the longest sections of 60mm hose. These had the lowest cost per foot. I ordered two of these, and cut them down in to smaller lengths as needed.
Edit: I went back and tried to look through PET, but it looks like they've removed the hose dimensions form most of the part descriptions, so this method isn't so easy any more.
Graham
1984 Carrera Targa
Old 06-14-2021, 01:12 PM
Nick
Great stuff on that site. But the air hose under the Porsche tab is $27 per foot!!
Old 06-14-2021, 01:29 PM
I've used this via Amazon for HE to engine blower. Cheap and durable and good looking (black).
https://www.amazon.com/Durable-Aluminum-Extendable-Replacement-Accessories/dp/B07ZGN3BQD/ref=sr_1_60?dchild=1&keywords=2.5%22+heater+duct+silicone&qid=1623715743&sr=8-60
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 06-14-2021, 05:13 PM
NickP's Avatar
Price has gone up since I’ve bought then. I guess it depends on your needs. For a car where you need/want all the details correct this is the right hose. I think I bought 5 feet and had enough for the engine to HE’s and for the blowers in the front trunk.
Euro Spec 73 911S
72T, now ST
Old 06-15-2021, 06:50 AM
gtc gtc is offline
abides.
gtc's Avatar
Parts Klassik has 60mm x 1.1 meter heater hose for $16.25.
911.211.522.00
Graham
1984 Carrera Targa
Old 06-15-2021, 05:05 PM
