Hesitation on carbs
I have 2.2 T freshly rebuilt, it had webbers on it but there was hesitation when I accelerated, had the carbs rebuilt but still the same hesitation, I decided to bite the bullet and get a set of PMOs (I have them on my 914-6 and they're great) but I still have the hesitation ☹️, I didn't replace the linkage could this be the problem or could it be something else, getting desperate now it's ruining my driving experience
Old 06-20-2021, 10:50 AM
Vintage Owner
Jack Stands's Avatar
Check your accelerator pump volume and ignition timing. You‘re probably going lean when opening the throttles.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 06-20-2021, 11:09 AM
also check valve lash (ask me how i know)
Old 06-20-2021, 12:01 PM
I just sent you a PM, I just finished a set on a 71 targa
Maybe I can help
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 06-20-2021, 12:39 PM
proporsche's Avatar
as Jack said you have to check you acc volume of gas..of course timing it right is a must..then report
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 06-20-2021, 12:42 PM
Brian, just a few quick checks . What are the jets in the carbs ?
34mm chokes , f11 emulsion tube , 125 main, 150 air , 55 idle, 130 idle air , ect ,, this is all from the PMO company. The pump rod needs to have a very specific length adjustment . measure the length of the threads showing past the adjusting nut , post this with all the jet sizes you have
My quick guess is that you will need a idle air jet change from 130 to 120 or 110 and a pump rod adjustment. Are the PMO's new ? the may need a pump cam update .
Ian
Old 06-20-2021, 04:33 PM
I would rather be driving
jpnovak's Avatar
check linkage balance L to R. If one side goes lean from improper linkage adjustment it will hesitate.
I have seen a few issues where the replacement linkage bars are not bent correctly resulting in arm length differences, This means that the arc travel is different L to R. Easy to correct with some careful measurements.
Make sure the balance is spot on before messing with the jetting. airflow issues will greatly mask the fuel delivery issues.
Old 06-20-2021, 07:26 PM
proporsche's Avatar
also, do you have the carbs balanced?
Ivan
Old 06-21-2021, 05:41 AM
