82 SC Fresh air blower fan help
My fresh air blower fan works but when I slide the lever completely to the right
(full speed) I need to back off the lever to get maximum flow.
Would there be a problem with the fan or the control lever or a cable adjustment?
Any help would be appreciate.
Joe
Old 06-14-2021, 05:28 PM
Spray a little electric contact cleaner in there and move the lever back and forth.
Old 06-15-2021, 06:57 AM
Its a matter of the contacts on the leaver not the cable.
Old 06-15-2021, 08:21 AM
There is a resistance coil in the box with the fan in the fruck. The fan speed lever moves a cable that slides the electrical contact across that coil which controls speed of fan I would give that a look, when you get it apart and look it will be self explanatory
82 SC Twin Plug 3.2 SS ,46 PMO
Old 06-21-2021, 01:32 PM
ROW '78 911 Targa
timmy2's Avatar
The contact choice for fan speed is made at the cabin slider switch. (Clean the contacts)
3 wires plus power go to the airbox motor from the contacts in the slider.
Each wire runs to a different resistor in the airbox that controls the speed.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-21-2021, 04:27 PM
