Kind of Blue
Stupid heater tube question
I want to replace my old, fraying orange heater tubes with some sleek black ones.
Can someone link me the right part? Do I need to cut some pipe to spec? I've come up with too many hits via google and I'm not sure which is the right one. ![]()
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
Try Aircraft Spruce and look for Sceet tubing.
Kind of Blue
Thanks. Looks like I'll need to measure the diameter.
I have used this for other parts of the heating system. I like it better than the orange or the Aircraft Spruce items. I think 60mm dia is correct for your application (but it never hurts to measure). It is plastic over paper over aluminum foil. Pretty durable compared to the older paper over aluminum.
Heater Duct Hose, Aluminum Ducting Auto Vent Flexible 60mm Diameter High Temp Reinforced Hot & Cold Air Duct for Webasto, for Dometic, for Planer, Can Reach 60cm ![]() I sourced it from Amazon ($15 for 2ft). Sent from my iPhone using Tapatalk
1985 Carrera 3.2 • Prussian Blue Metallic |
I ordered from Aircraft Spruce as some have recommended. Works perfectly.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Black over aluminum or brown over aluminum from a supplier in Texas by the name of Z I M S. Have a look.
76 911S Land Rover 110 Defender |
