-   -   911SC. Problem with old vs new ignition switch assembly (http://forums.pelicanparts.com/porsche-911-technical-forum/1097192-911sc-problem-old-vs-new-ignition-switch-assembly.html)
acrylic66 07-05-2021 10:58 AM
Hi all, after an attempted theft of my '77 SC, the ignition was damaged so I've purchased a new lock set.
The original part is 91161301101, the newer replacement part is 96434701701.
My mechanic says the new one doesn't fit, that's it's too long and hits the bulkhead.
But the part is the replacement recommended by PP and Porsche.
Has any one had any experience of replacing the old with the new?
http://forums.pelicanparts.com/uploa...1625507871.jpg
proporsche 07-05-2021 11:11 AM
it should fit without any problem if your mechanic knows how to put it in...
Ivan
on another note i would buy the old one from you if you like..?
acrylic66 07-05-2021 11:33 AM
Ivan
Thanks Ivan, that's the problem though, he's not sure how, hence why I'm on here.
I'll be selling the old one eventually but the tumbler is damaged with something jammed in it from the attempted theft.
Harpo 07-05-2021 11:43 AM
I installed a new ignition switch (mechanical & electrical) and it fit but I did have to remove all of the steering column bolts.
proporsche 07-05-2021 11:50 AM
just make sure he removed the security bolt(allen insert tool) completely..also the dash plate s off?where the original rivets were?No need to install the rivets at all. just 2 allen head screws to hold it in place...
I know it is bad tumbler -i would not have problem with that.
acrylic66 07-06-2021 01:00 AM
Thanks Harpo, I got more clarity from my mechanic. The 964 part goes in ok but there’s not enough room to put the electrical cap on when it’s in. And apparently it’s problematic if you put the cap on first. Did you have this issue and how did you resolve it?
Thanks!
Dpmulvan 07-06-2021 07:55 AM
No such car as a 77 sc. Sc 78-83
acrylic66 07-06-2021 09:16 AM
The model year is 78 but it was manufactured and registered in 77 according to the registration docs. From what I know the MY runs from the August the year before.
proporsche 07-06-2021 09:40 AM
if it is 77 late it is consider 1978...that what everyone will call it;-)nice to have ..had one too sold it back in LA to France;-)is your black?
Ivan
proporsche 07-06-2021 09:46 AM
acrylic .i`ve sent you a PM on right top corner ..
Ivan
