78 SC Targa
911SC. Problem with old vs new ignition switch assembly
Hi all, after an attempted theft of my '77 SC, the ignition was damaged so I've purchased a new lock set.
The original part is 91161301101, the newer replacement part is 96434701701.
My mechanic says the new one doesn't fit, that's it's too long and hits the bulkhead.
But the part is the replacement recommended by PP and Porsche.
Has any one had any experience of replacing the old with the new?
Old 07-05-2021, 10:58 AM
proporsche's Avatar
it should fit without any problem if your mechanic knows how to put it in...
Ivan
on another note i would buy the old one from you if you like..?
1985 911 with original 502 191 miles...808 198 km
Old 07-05-2021, 11:11 AM
78 SC Targa
Ivan
Thanks Ivan, that's the problem though, he's not sure how, hence why I'm on here.
I'll be selling the old one eventually but the tumbler is damaged with something jammed in it from the attempted theft.
Old 07-05-2021, 11:33 AM
Harpo's Avatar
I installed a new ignition switch (mechanical & electrical) and it fit but I did have to remove all of the steering column bolts.
Old 07-05-2021, 11:43 AM
proporsche's Avatar
just make sure he removed the security bolt(allen insert tool) completely..also the dash plate s off?where the original rivets were?No need to install the rivets at all. just 2 allen head screws to hold it in place...
I know it is bad tumbler -i would not have problem with that.
Old 07-05-2021, 11:50 AM
78 SC Targa
Thanks Harpo, I got more clarity from my mechanic. The 964 part goes in ok but there’s not enough room to put the electrical cap on when it’s in. And apparently it’s problematic if you put the cap on first. Did you have this issue and how did you resolve it?
Thanks!
Old 07-06-2021, 01:00 AM
No such car as a 77 sc. Sc 78-83
Old 07-06-2021, 07:55 AM
78 SC Targa
The model year is 78 but it was manufactured and registered in 77 according to the registration docs. From what I know the MY runs from the August the year before.
Old 07-06-2021, 09:16 AM
proporsche's Avatar
if it is 77 late it is consider 1978...that what everyone will call it;-)nice to have ..had one too sold it back in LA to France;-)is your black?
Ivan
Old 07-06-2021, 09:40 AM
proporsche's Avatar
acrylic .i`ve sent you a PM on right top corner ..
Ivan
Old 07-06-2021, 09:46 AM
Tags
ignition lock
